Need Help Replacing Part
Old Feb 26, 2018 | 10:46 AM
tjackson9810's Avatar
My Ride: 2004 525i
Default Need Help Replacing Part
Hey Everyone,
Today I was trying to remove the cross brace (Part # 51617046555) from my car and stripped the head of the T45 bolts. I tried drilling the heads to remove it and it worked, but when I tried removing the center bolts, (located near the firewall / cabin air filters) I drilled into the "nut" the T45 bolts were attached to. Do you guys know what part number it is and how to replace it?
Thank you
Old Feb 26, 2018 | 03:50 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
Is the stripped "nut" a loose item? If not just heli-coil (or equivalent) the thing.
Old Mar 1, 2018 | 11:09 AM
Gee_115's Avatar
My Ride: 07 550i Sports Package
Originally Posted by tjackson9810
Hey Everyone,
Thank you
Hard to tell exactly what part you are talking about without seeing pics. Anyway, try this part number 51617010593 to see if this is what you need. If not, go to RealOem and search under body reinforcements.
Old Mar 6, 2018 | 01:06 PM
My Ride: 2004 525i
Sorry for the delay. Here are some pictures of what I'm talking about. I drilled into the "nut" diagonally and the bore isn't round anymore.
Old Mar 6, 2018 | 01:08 PM
My Ride: 2004 525i
Old Mar 6, 2018 | 01:37 PM
ripley's Avatar
Engine: M57
I couldn't see these nuts on realoem.com - but I was looking at a 530d.
If a 21/64th (8.3mm) drill is a tight fit in the hole or better it can be re-coiled (assuming there is enough meat there).
Any decent shop could do it. Or ebay for about $15.
Old Mar 12, 2018 | 05:33 AM
cmyachtie's Avatar
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
Hey Everyone,
Thank you
This should help u out
Attached Thumbnails Need Help Replacing Part-8421c8fd-4a20-414c-be31-2b4057177554.jpeg
rev run d
Feb 28, 2016 07:35 PM
neopoint
Jul 6, 2011 08:54 AM
jashy247
Jul 22, 2010 10:55 PM
Sajjid
Feb 1, 2008 06:14 AM
kreate2
May 21, 2006 01:37 AM
