Need help!! Problem with HID xenon fog lights
Old 01-31-2005, 07:43 PM
  #31
EBMCS03's Avatar
Speaking of HIDs these are what I was talking about REAL HIDs with Ballistics and all that "spark" up when you initially turn on the light.
http://www.hidexpress.com/index.asp?PageAc...WPROD&ProdID=14
Heres a good color scheme for the Kelvin Rating. So you see the higher it goes the bluer it gets and then goes to purple!
Old 02-01-2005, 05:47 AM
  #32
Ed520's Avatar
yeah i was also wondering whether there is any way i can remove the warning if i install a xenon conversion kit....any ideas?
Old 02-01-2005, 05:59 AM
  #33
Guest
Guest
Posts: n/a
[snapback]85527[/snapback]
The above website shows a $80 option to remove the warning. How they do it I dont know.
Old 02-01-2005, 03:59 PM
  #34
Guest
Guest
Posts: n/a
Originally Posted by EBMCS03' date='Jan 31 2005, 11:31 PM
[quote name='Viper786' date='Jan 31 2005, 07:07 PM']quick question... if i do not have xenons in my bmw, can i just get HID bulbs and put them in there with the same wiring? and will i get that sweet blueish color?
If yes, can someone suggest a bulb?
This is for the low beams btw... not the fog lights
[snapback]85392[/snapback]
Technically speaking they are not High Intensity Discharge bulbs with real HIDs you need a complete setup with Ballistics and all. these bulbs only give the "look" of HIDs
BUT Sure you can do it, the safest bulb to go with would be the Osram Sylvania SilverStar H7ST they are ~4000K which will be very close to the BMW Xenons in "WHITE-ness / BLUE-ness" BMW Xenons are ~4200K as stated above somewhere.
http://www.sylvania.com/ConsumerProducts/A...ine/default.htm
The 4th to the last bulb on ^^^ page. You can get them at the local Parts store... I thnk they're about $24 a bulb.
If you want more blue then go ahead and look for a 4700K bulb from PIAA or somthing but I dont know the exact ones to get but as long as they are H7 type then you are ok. Try to keep within the approx Wattage so you wont be drawing too much current on existing wiring. and of course 12 Volt bulb.
The H7ST are 12V 55W so they are same as OEM.
[snapback]85421[/snapback]
[/quote]
Thanks, but if i buy these bulbs, i just can't replace them? there is more to be done? if so, what is the overall cost? (approx)
Old 02-01-2005, 04:06 PM
  #35
Viper786's Avatar
My Ride: 2009 528xi, Jet Black, Black Dakota Leather, Poplar Wood, Steptronic Transmission, Premium Package, Cold Weather Package
^oops that was me^
Old 02-01-2005, 05:13 PM
  #36
EBMCS03's Avatar
[snapback]85867[/snapback]
Ya theres some to be done. the bulbs do just install into the existing slot but you have a figure out where to put the Ballistics and the wires that connect to it. I wouldnt think its too hard but I dont know.
Kasmo
05-07-2019 03:30 AM
Beemer
33
01-14-2019 05:13 AM
EuroStyle
05-04-2015 05:42 PM
tjackson9810
04-21-2015 07:42 PM
umnitza
04-16-2015 04:39 PM
Quick Reply: Need help!! Problem with HID xenon fog lights
