Need Help 2005 525
Hi all, I had to replace the starter in my car, in doing this I removed the intake. Everything is back together but now I have a code. Cylinder #5 misfire? I switched coils and same thing. I removed the code and it comes right back. I am stumped as I cannot find anything out of place. I used new seals on the intake, checked the air filter and checked all related plumbing. I replaced the hose at the back of the intake with the wire because it was brittle. I also had to replace the previously damaged plug on the crank sensor. At this point this car is beating me and I need to find the problem asap as this is my daily driver. Thanks
Bank$hot530
09-16-2015 01:28 PM
