Need help!
I would like to change the V shaped plastic thingy on my M sports steering wheel with the aluminium one found only on the 545i. Is that possible without changing the whole steering wheel? I tried to find the part number but all i found is the same thing on the 545i and on the 535d (and i know things are different).
And 2nd i'd like to change my brake and accelerator pedal with metal ones. I know the M5 has metal ones not rubber as on the rest of the 5 series. M i right? If it has please let me know and please if it is possible tell me the part number. If it doesn't where can i find some M metal padels?
THANK YOU ALOT IN ADVANCE!
Found this thread from a little while back, hope it helps.
cheers,
jack
http://forums.e60.net/index.php?showtopic=10392
cheers,
jack
cheers,
jack
cheers,
jack
[snapback]162862[/snapback]
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by BetterMakeWay' date='Aug 24 2005, 05:56 PM
Do you know if those clips would fit on my sport steering wheel also?
[snapback]162887[/snapback]
Sport steering wheel... Yes.
Standard steering wheel... Yes.
[snapback]162798[/snapback]
...currently no E60 OEM aluminium pedals are available, neither for M5 or M6 either, only the kickplate as of yet...im also going to look to change to alum pedals when i get mine, but, if no OEMs are available, i'll probably go for AC S or Hamman/Hartge, they all have nice pedal kits....
there are also some cheaper imitations that have the M logo if you just want the look, check the mod's forum and you will see some members that have done this, here is one recent thread: http://forums.e60.net/index.php?showtopic=14757&st=0
Originally Posted by m630' date='Aug 24 2005, 03:52 PM
[quote name='BetterMakeWay' date='Aug 24 2005, 06:47 AM']
[snapback]163007[/snapback]
[/quote]Thanx alot! I guess i have to look at tuners like u said.
Originally Posted by Iceman' date='Aug 24 2005, 01:30 PM
[quote name='BetterMakeWay' date='Aug 24 2005, 05:56 PM']Do you know if those clips would fit on my sport steering wheel also?
[snapback]162946[/snapback]
[/quote]Do you know the part code for the ones for M steering wheel ?
