navigation retrofit
Hi Guys !!! I bought my car Feb. o4 production date is late 03. I dont have a navigation and is not pre wired.
How much to do a retrofit navigation ?
Is it worth paying ?
Im in Los Angeles, California.
Thanks for your time
My Ride: [i][b][u]Since 19 august 2004[/u][/b][/i]: [color=red][b]530i[/b] High Executive[/color], Silvergray with beige interior, Popular wood, Servotronic, Sportssuspension, electric foldable and dimmed mirrors, dimmed interior mirror, pappelmaser braun wood, cupholders, styling 123 18" wheels, Logic 7, Steptronic, alarm class 3, electric sunscreen in the rear and suncreens for sidewindows, Comfort seats, heated seats, Xenon with headlightwashers, Adaptive corner lights ALC, Advanced airconditioning, lightpackage, Nav Pro, 6 cd changer, side airbags rearseats, bluetooth siemens S55, chrome kidneys, gearlever with wood, voice recognition retrofit, front windshield with green band.
Waiting for trunkopener button from Hobi :)
I don't know how much the retrofit is but I was wondering how your I-Drive main screen looks. I think you don't have the option to click to the right due to the fact that there normally the navigation option is..
My Ride: E90 M3
Model Year: 2011
for 530E60NL, those of us without NAV have the smaller iDrive screen where pushing the controller to the right brings you to a "Car Data" menu for the trip computer, etc.
Hi Bstuff,
How do you know that your car is not prewired? Retrofit cost $1800+tax totally. You don't have to pay for labor.
Someone posted this, and I repost it here.
FYI:
The US TIS bulettin says they can not charge you more than 1800USD
This Service Information bulletin supersedes Advance S.I. B84 10 04 dated June 2004.
designates changes to this revision
SUBJECT
CCC (Car Communication Computer) Navigation Retrofit Kit
MODEL
E60 (5 Series) with CCC pre-wiring (option 6UA).
SITUATION
NOTE: CCC retrofitting is only possible if the vehicle has option 6UA (Pre-wiring for CCC) installed.
NOTE: If the customer requests that the Navigation retrofit be installed, they are not be charged more than $1,800.00 in total.
Warranty is to be charged for the Labor and the color specific cover, center dashboard trim panel.
Please also refer to the Sales Bulletin.
INFORMATION
Contents of the CCC Retrofit Kit.
[S6504U17.JPG]
A CCC with In-dash CD drive
B 8.8" Control Display
C LVDS Cable
D Menu/Speech button (Not included in the CCC Retrofit Kit. If necessary order separately)
E Protective strip
F Cover, center dashboard trim panel* (Not included in the CCC Retrofit Kit)
G Clip
H Screw
I Tie wrap
J Road Map DVD* (Not included in the CCC Retrofit Kit)
* Has to be ordered separately.
PROCEDURE
Important: Before doing the Installation, update the complete vehicle with CIP12.0 or a more recent CIP version.
Connect the vehicle to an approved BMW battery charger.
Using DISplus/GT1/SSS, with the diagnostic head connected to the vehicle, select Coding/Programming. Refer to SIB09 05 01 (Coding, Individualization and Programming) Procedure B for any necessary coding and programming. Note that CIP will automatically reprogram all programmable control units that do not have the latest software.
Disconnect the DISplus/GT1/SSS after the update is finished and no additional work has to be done
Install the CCC retrofit parts, please refer to the Installation Instruction P/N 01 29 0 394 108 in ASAP on the CenterNet website.
Reconnect the vehicle battery.
Using DISplus/GT1/SSS, with the diagnostic head connected to the vehicle, select Coding/Programming. Refer to SIB09 05 01 (Coding, Individualization and Programming) section "Retrofits".
PARTS INFORMATION
Part Number
Description
Quantity
65 90 0 390 844
CCC Retrofit/Conversion Kit US
Road Map DVD
1*
65 82 6 921 669
Menu/Speech button
If necessary
51 45 7 063 152
**Cover center dashboard trim panel, black
**Cover center dashboard trim panel, gray
**Cover center dashboard trim panel, beige
**Cover center dashboard trim panel, brown
** dependent on the interior color. Has to be claimed under warranty.
WARRANTY INFORMATION
Warranty claims can only be submitted until May 31, 2005.
Defect Code
65 83 91 23 00
Labor Operation:
CCC Retrofitting and programming
the control units
Labor Operation
Labor Allowance
00 54 284
FRU 25
+00 54 983
FRU 23
Parts Allowance:
Quantity (1)
Part number depends on interior color
Labor Operation:
the control units (including CAS)
Labor Operation
Labor Allowance
00 54 285
FRU 27
+00 54 984
FRU 26
Parts Allowance:
Quantity (1)
Note:The following explanations will spell out the correct use of the work times.
Main Work:
Use this labor operation number when the only repair performed is the listed warranty repair.
OR
+Associated Work:
Use this labor operation number when other repairs or services are performed along with the listed warranty repair.
Under no circumstances should both labor operation numbers be claimed. Attempts to claim both times will result in an unnecessary delay in claim processing and payment.
WARRANTY PART RETURN INFORMATION
A part tag and the credit note will advise you to return the cover, center dashboard trim panel.
We do not need this part but must receive the 6.5" control display and the M-ASK control module.
The M-ASK and the 6.5" control display were removed from the vehicle to permit installation of the NAV Retrofit Kit.
Please attach the part tag for the cover dashboard trim panel to the box containing the 6.5" control display and the M-ASK.
[S6504U26.JPG]
Place the removed 6.5" control display in the box in which the new 8.5" board monitor was supplied (1).
Place the removed M-ASK in the box in which the CCC was supplied (2).
[S6504U27.JPG]
1. Place the box containing the removed 6.5" control display (1) and the box containing the removed M-ASK (2) in the large box in which the kit was supplied (3).
When requested by BMW NA, ship the removed components to BMW WPRC using the regular parts return procedure.
FYI:
SUBJECT
MODEL
SITUATION
INFORMATION
[S6504U17.JPG]
C LVDS Cable
E Protective strip
G Clip
H Screw
I Tie wrap
PROCEDURE
PARTS INFORMATION
Part Number
Description
Quantity
65 90 0 390 844
Road Map DVD
1*
65 82 6 921 669
Menu/Speech button
If necessary
51 45 7 063 152
Defect Code
65 83 91 23 00
Labor Operation:
the control units
Labor Operation
Labor Allowance
00 54 284
FRU 25
+00 54 983
FRU 23
Parts Allowance:
Quantity (1)
Labor Operation:
Labor Operation
Labor Allowance
00 54 285
FRU 27
+00 54 984
FRU 26
Parts Allowance:
Quantity (1)
Main Work:
OR
+Associated Work:
[S6504U26.JPG]
[S6504U27.JPG]
[snapback]38549[/snapback]
Wow !!!!!!!!!!!!!!! Thanks for the info. Thats answer all the questions.
bestofthebest
03-28-2016 02:47 PM
umnitza
09-02-2015 11:28 AM
