N52 RPM bounces on cold start
My Ride: 530xi
This started happening a while ago and I have read a lot of threads about this with no definitive answer. It is usually around 750-1250 rpms. The needle moves around in that range for about 15-30 seconds and then settles down to 600 rpms. While it is bouncing the car vibrates almost as if it is misfiring.
Ideas?
I have cleaned the throttle body (it looked very clean) and the MAF looks perfectly clean too. I have used many gas stations between now and when it started. I am about to change the air filter (it is overdue) so that could be it, but it seems too violent for that.
Ideas?
crankshaft sensor, slight air leak, could be a whole load of things, check the rubber pipes to the intake manifold for cracks, even the breather pipes as they perish over time,
have had a few issues with my e46 330ci n your engine is the newer one to mine so must be similarish
hope this helps
hope this helps
Could be something as simple as a loose/cracked vacuum hose or incorrectly fitted oil filler cap (fairly common by the way) - OR, something electronic/ignition related - OR whatever
Might help if you provide your car's mileage and service / repair issues history?
I have a 2008 528Xi that does the same thing. I bought the car with 9000 miles 3 years ago, can't remember if it did it early on or not. It's done it for the last couple years, the car now has 91,000 miles and it hasn't gotten any worse. I recently bought a 2008 Z4 with 18,000 miles, it has pretty much the same engine, and it does it also. They both rev between 700 and 1200 rpm for the first 30 seconds or so when I start them cold in the morning, then they smooth out & run fine. Since both cars do it, I guess I'm not worried about it.
chadillac2000
42
09-13-2017 11:15 AM
