N52 engine problem
My Ride: 07 E60
It will be a direct swap, because you are going to have to re-use your entire oil filter housing, yours has provisions to attach the cooler, the 325 housing will not. Replace the gasket from block to housing, and housing to cooler while your at it, these is a common maintenance issue. I'm sorry i don't know about the actual swap. Good luck!
The engine and transmission are both out from the 325. Took me 1.5 hours to remove exhaust, driveshaft and transmision. And about 3 hours for the engine. It was really easy since the car had no front bumper, headlights and other crap lol. But it is going to be pain on the E60 since i have to reuse all the wiring and other components. Again, Thanks a lot of any of the help that has been contributed.
