N52 engine problem, help with N52 to N52 swap
Hello everyone,
I have a 2007 530i with engine problem. It has 140k miles.My car started to misfire, checked the codes and it was cylinder 6, there is no compression at cylinder 6. I haven't opened up the engine to see what is wrong with it. I am just to swap the engine with a used engine.I have been searching for engines and they are in $3k range with low miles. Now, my question is that which engine can I use, I see that E90 N52s are cheaper than E60. I wouldn't mind swapping the parts, just want it to work. I just want to know if all N52 engine are compatible. Also, Can I use the 528 engine since it has upgraded head(no ticking). I will be doing all the work myself. Also, I was thinking of buying parts car so I can use the engine and sell the rest of parts. I would really appreciate if you can help me out. |
why dont you just fix it? i mean how bad could it be? Swapping engine seems overkill no?:ermm:
This wikipedia link should give you some guidance
https://en.wikipedia.org/wiki/BMW_N52 Of course as with anything published on that site you need to check the article for reference. I think that there are differences among the engines installed in the various models; e.g. the camshaft and/or inlet manifold might be different. You might also need to transfer the engine controller over along with the engine itself if you go outside of the 2006/2007 E60. |
It's not uncommon for the valvetrain to fail, preventing the valves from sealing properly. This would mean a new head, or maybe just a repair. I think an engine swap is a little heavy handed given what you've shared this far. Also, there are differences between the n52s in different platforms.
Originally Posted by Andrew06
(Post 1574503)
Correct me if i am wrong, As far my research goes, 06-07 525/530 and 06-07 325 or 330 has the same motor(N52B30) but have different intake manifolds. Again, i really appreciate all the help.Thank you |
Originally Posted by rizwan1377
(Post 1574515)
I have discussed it with few people and have been told that i would need BMW special tools for timing chain and others and its seems bit complicated . I am sure the valves are bent & head needs to be repaired or replaced. So that is why i am hesitant to tear apart the motor. So the best route for me is to swap the engine with a used one. So, i have decided to stick with N52B30 so it is a direct swap, so i dont have to deal with swapping the ECU or what not.
(Post 1574589)
I see, maybe your right, i don't imagine it's fun to spend time in the head of these compicated motors. The 30 series motors do have the better intake manifold, i'm unsure if it's 3 stage or continuously variable, but just reuse the intake from your engine. The 25 series engines have a lesser intake, and no oil cooler, so you'd have to reuse your oil filter housing and cooler. I'm sure you know this, but make sure to replace the blue top fasteners, they are aluminum, and many are not reuseable. Good Luck!
So actually today i bought the 2006 325i with the N52. It has front end damage. I got it for less than $1000. Has 100k miles, Salvage title and came with no keys, I know!! I guess, i will have to take the risk. The guy who i got it from, has a yard and uses cars for body parts. Even if the engine is bad, i can sell the rest of parts and cover up my cost of buying the car. Is there a DIY guide for dropping the engine? Should i take out the engine and transmission both together or separately? & thanks again for any of the help. |
The engine in the 528i and 328i makes less power. You will need to swap over the 3 stage manifold from your 530i engine and retain the exhaust piping. You will also have to swap over the ecu from your 530i in order to make the n52 you swapped over equivalent to what you had previously.
http://www.e90post.com/forums/showthread.php?t=372973 check that thread out. |
Originally Posted by zoppp
(Post 1574684)
325i to 330i conversion successful! Dyno charts included! check that thread out. |
(Post 1574611)
Thanks for the help. I did knew about the intake and the blue top bolts but not the oil cooler, but hoping it is a direct swap.
