My iDrive has died twice now
My Ride: 2007 530i, white/black manual, sports package, nav, PDC, etc.
On 2 occassions, I've started my 2007 530i only to discover that the entire iDrive system is totally dark and nonfunctional. Letting the car sit for an hour or more cures the problem, but it's happened twice now. I do have the v25.02 upgrade and the problems began after the upgrade.
The problem is too intermittent to demonstrate to a dealer. Are fault codes recorded?
Thank you,
Robert
Thank you,
Robert
My Ride: 520d
Going back to dealer at the end of this month... To their knwoledge, no specific issue recored yet... But it seems some of us (many ?) are complaining with this issue, so who knows, it might get some fix some day ....
My Ride: 2006 530D SE; Mystic Blue; Beige Leather; Luxury Pack; Media Pack; Visibility Pack; 123's; Logic 7; + to many more to type...........
2008 730D; Black Sapphire; Cream Beige Leather; plenty of options!
Thank you,
Robert
Thank you,
Robert
If you do a search on the forum for iDrive problems you'll find that you're not alone. My own experience with this problem lasted 4 months until a solution was provided; I suspect you'll be able to secure a fix much quicker, I hope so!
You state the problem started post your v25 upgrade which is the common thread here as mine did too, except mine began by crashing and re-booting at will when driving, it then moved on to also not booting up from start up on occasions.
As to errors, there might be error codes stored - in my case there were not any error codes present. Evidently when an e60 is hooked up online to BMW gmbh they are able to 'see' a deal more within the software and exercise more invasive diagnostics than the dealer was allowed to see or do (my dealer is frustrated by this point as they feel they?re letting the customer down by requiring to call on BMW each time to do this with the long delays this entails); despite BMW intervention however they could not replicate the problem therefore find a definitive solution, at that point the CCC was authorised to be replaced again.
It may be a fix will be found by the dealer reprogramming the upgrade again, in my case BMW insisted that the dealer and they, BMW, do this in tandem; a total of three times they tried before they gave in and finally replaced the CCC again! I'm now on my third CCC; my e60 has behaved for two weeks now without a crash, or a failure to boot up.
I had the same problem. While the screen was blank, I took the car directly to the dealer and told them not to turn off the car. The shop foreman checked the car out and then replaced one of the processors. A week later I had the same problem. The shop foreman said that there should be a software fix for the problem coming out. My feeling is that the last software upgrade to the car was responsible for this i-drive problem on certain cars.
Originally Posted by mooseman' post='469151' date='Sep 13 2007, 05:22 PM
My feeling is that the last software upgrade to the car was responsible for this idrive problem on certain cars.
The unstable iDrive problem surfaces post a software update - a number of contacts I've made recently both in the USA and UK are suffering unstable iDrive problems post a software update.
In conversation with my (UK) dealers engineer recently he opined that older CCC units were more sensitive to reprogramming - recently manufactured CCC units are not found to cause these problems, in his experience; he stated he has reprogrammed many, in the hundreds, e60's and senses that newer (later) units were not so sensitive to reprogramming - he also commented that he'd noticed there are re-conditioned (older) CCC's being recycled as replacements within the parts system which are contributing, in his view, to the continuing number of failures when used as replacements by dealers; with my e60 he had tried two ?older? CCC units before sourcing a newer unit (not a recycled unit) which has cured my e60?s unstable iDrive. His view and one that has a deal of experience supporting his conclusion?????
Thank you,
Robert
Thank you,
Robert
