My car tried to off itself today
My Ride: 2004 545i 6 speed, Silver Gray A08, Gray leather
Mods: Hard-Wired Passport 9500ix LIVE , K&N Air + RPi Scoop, Mtech V2.1 AE, ACS pedals+Ebrake, flip up front plate, OEM 172's, Custom M Kit, M3 shift knob, Eisemann Race Exhaust
2005 X5 3.0 (the nightmare)
1998 528i SOLD @ 173K
So drive to work this morning almost there I start smelling some burning like oil. I've smelt it before I know the valve cover gaskets are slowly leaking and I think nothing of it. Pull into the parking lot to see white smoke coming from the grills. Parked and oil is pouring out the bottom puddle about 2 feet long and hitting both tires seemed like the smoke was coming up from in between the drivers side of the motor and the intake. Over at the Indy now waiting to hear back. Anyone ever have this happen? Oil cooler line that burst. cracked oil filter housing? So strange, car sat all weekend and when I got home today noticed a puddle here too.
My Ride: 04 530i
Shadow line mod
Rpi scoop
BMC air filtter
Ksport coilover
Mtech V2 Angel eyes
HID low beams
HID Fogs
Real bummer dude, sorry to hear that.
GL with the repair - keep us posted.
My Ride: 05 BMW 530I
I have never heard of that happening unless you have had a recent oil change. Maybe the oil stand gasket? Make sure you keep us posted on the outcome!!
I did the oil change at the beginning of the month and have gone over a thousand miles since then. Hopefully Ill get it up tmrw and see whats going on. Got my fingers crossed on this one
Probably the oil cooler gaskets - easy fix, if so. It may also be the oil pan gasket - or whatever it's called - this is more complicated. Either way though, it is definitely fixable - hang in there, bud
Looks like it going to be the gasket behind the alternator bracket. Fingers crossed!
So here we go! Got the car torn apart today and after many many f bombs and hearing If I could find the guy who designed this car and punch him in the face... Found the problem! Gasket behind the alternator bracket for that hole in the engine that goes nowhere. Awesome took a good 5 hours to do the job, had the remove the motor mounts, jack the engine up, managed to keep the radiator in and just remove the fan, and not remove the subframe! Hell of a job feel sorry for my mechanic. The gasket was cracked in 2 spots and completely flattened out and brittle. Attached a couple pictures of it. Got the car all put together went to put the belt on, tensioner broke local dealer didnt have one had to drive to rochester to get one! Yikes merry xmas to me!
Forgot to mention I lost 4 qts of oil too.. Interestingly enough the light never came on that said i need to add oil... Can't ever trust these damn cars. Im glad I at least have a dip stick.
