my 550i 1/4 mi times
you seem to be having a hard time digesting my words ... i mean after i past the 1/4 mark a little after i mean mabey 100 ft or 200ft in tip tronic mode i was at 130 mph plus ..in auto mode i was at about 110 so .. i have many motorcycles and cars before im 25 years old and believ me i know how to shift and when to the tiptronic mode is controlled by the ecu and when it senses the cars speed to be low it will not kick up to higher gear under hard acceleration .... i hope this clears things up ...
Originally Posted by bmw528i' post='287717' date='May 25 2006, 03:40 PM
oh and if you would also like to know i smoked the folowing vehicles at the track on my three runs
1) 2000 camaro v8
2) 2001 mustang v8
3)all hooked up jap mitsubishi evo
1) 2000 camaro v8
2) 2001 mustang v8
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
The 13.7 at 104 is a good starting time for tests,but I am sure as you get more miles on your car and experiment with different starting methods you will improve those numbers.You must check out Znods threads.there is a wealth of info on 545 testing.My best uncorrected for weather time is 13.25 at 106.3.This was done in very cold and dry weather conditions.Also I can duplicate my times weather in D or "tiptronic" mode,or with DTC/DTS on or disabled.It all depends on how much wheelspin I get.
do you know how fast the 550i accelerates in 4th gear when the pedal is nailed trust me pal only a few seconds from 110 to 130
i ran the times at 80 f weather kinda humid but not too bad ... mabey i could have done better i did not do anything but nail the gas pedal to the floor when the light hit green all the way past the 1/4 .....
I also noted that your 330' time is unrealistic.A time of 5.2 sec would equate to a 1/4 time under 13 sec.I believe that time is more like 5.8 sec for 330'.Having read plenty of drag strip time slips I noted that the printout is hard to read sometimes and a 8 may look like a 2.The other numbers are as expected.
