More info on USB in the LCI
Old 03-18-2007, 06:52 AM
  #41
JSpira's Avatar
Originally Posted by TC.' post='403801' date='Mar 17 2007, 02:45 AM
I intend taking along a 3.5mm cable and the usb cable to try this out when i pick the car up - I am not expecting it to work though as the cable splits the usb output from the iPod into usb and 3.5mm - taking a direct feed from the phone socket doesn't appear to be supported (will work for straight forward playback as we see now with the AUX-in but without iDrive file structure).
It's a problem for a different reason. That output is amplified. That's bad.
Old 03-18-2007, 07:00 AM
  #42
aybeesea's Avatar
Originally Posted by TC.' post='404136
...the Aux-in port in the back of the console is gone.
As a TV personality in the UK says...
"Two opposing views, but which is the right one? There's only one way to find out........ FIIIIIIIIIIIIIIIIIIIIIIIIGHT!!!!"
ABC
Old 03-18-2007, 07:53 AM
  #43
JSpira's Avatar
ABC
True. Or you could read my article
Old 03-18-2007, 07:54 AM
  #44
JSpira's Avatar
Just so no one is confused, although I indicate the Aux-in port in the back of the center console is gone, I also indicate that it has moved INTO the console.
Old 03-18-2007, 08:14 AM
  #45
aybeesea's Avatar
I could. Are you a recognised authority on this learned topic?
ABC
Old 03-18-2007, 08:27 AM
  #46
JSpira's Avatar
ABC
I believe so.
Old 03-18-2007, 09:06 AM
  #47
aybeesea's Avatar
Originally Posted by JSpira' post='404246' date='Mar 18 2007, 04:27 PM
I believe so.
Excellent. Would you care to give a reference to your article?
ABC
Old 03-18-2007, 09:12 AM
  #48
JSpira's Avatar
ABC
Of course. The only one online on the subject is at http://www.bmwcca.org/node/7241. There is another that will be in a print mag.
Old 03-18-2007, 10:18 AM
  #49
aybeesea's Avatar
Sorry to have a vote of no confidence in a small aspect of your article.
The USB jack installs in the center console next to the existing AUX-IN jack
We believe it doesn't, don't we? Rather, there's a NEW AUX-IN jack located in the compartment under the armrest, under the telephone cradle.
Also no mention in your article about the EXISTING AUX IN (in the REAR of the centre console) being deleted or superseded by the addition of this new option.
Being "recognised authorities", unfortunately doesn't make them necessarily right. It happens quite often when experts are summarising published information is a dissertation rather than delivering first-hand knowledge in a thesis.
BTW
While the USB option doesn?t conflict with the CD changer, it?s unclear why anyone would want a changer nowadays
There must be many who have never compared MP3 and CD audio.
ABC
Old 03-18-2007, 01:27 PM
  #50
JSpira's Avatar
This isn't terribly complicated. For the 5er, the existing aux-in jack has been moved into the console (my article of course is not specific to a specific range of BMW btw).
The USB port is next to the existing aux-in, whether it's been moved or not (again, depends on range).
Quick Reply: More info on USB in the LCI
