Monitor stopped working
Hi, my e60 monitor stopped woking yesterday, i tried to charge battery, because it was discharged, but it didin`t work. Everything works perfectly except monitor. Any ideas for fixing that problem?
My Ride: Bmw 530d 2004
Originally Posted by e60LT' post='788580' date='Feb 9 2009, 06:25 PM
anyone?
Then second, sorry to hear your problem.
So your battery was discharged. How did that happen? Have you had any problems with it earlier?
If yes, maybe the battery is gone, and recharging it to its full power can't be done anymore.
Bad battery "cuts" some electric devices off and can make some mysterious malfunction messages. Maybe you should try with a new battery
Thanks for the help. It discharged, because it was -20c temperature outside. The battery is original, and the light in it seems to be green. Engine stars normally. Another problem is that i can`t put any CD compacts.
What do you mean by can't put any CD compacts?
Sure this CD and iDrive screen problem can be related and some module has broken. But try another battery at first
My Ride: Gone Waiting
Originally Posted by e60LT' post='788580' date='Feb 9 2009, 12:25 PM
anyone?
Disconnected the negative terminal on battery for 2 hours, didin`t help. Tried another battery, also put wires from other car`s battery, same problem. Any new ideas? CD player don`t accept CD.
I'm having the same problem with the monitor. It sucks that it doesn't work because the idrive controls the radio/temp...The battery never gave me problems before, I didn't drain it, and it starts just fine.
If anyone could help with more ideas that'd be great. Otherwise I'll get the dealer to look into it for the passenger seat recall.
DavaiLave
08-02-2022 02:16 AM
