MKIV? MKIII? Nav software version help
My Ride: E61 Titanium-Grey, Leather Dakota Black, 525d, Steptronic, Navi Prof & TV, Voice Input, Panorama ceiling, Xenon with dir, etc
Hi,
I am new here and just got a 525d from BMW de from August 2004 with Nav Prof. How do i know the version of the nav system?
Where does the MKIV or MKIII enter? And the versions v25, v26 i see around?
The system information on the system menu is here so where do i see what my car has?
ECU List:
C-Application
SystemNameOrEngineType:19273
VehicleManufactureCodingIndex: 5
SystemECUHardwareNumber:000004133544
MsgCatalogueVersion:000.010.148
DateOfManufacturing:01:07:2004
VehicleManufacturerDiagnosticIndex: 2352
OperatingSystemVersion:000.000.000
VehicleManufacturerECUHardwareVersion:68
FunctionalSoftwareVersion:005.104.001
SystemSupplierIndex:SVDO
C-Host
SystemNameOrEngineType:17996
VehicleManufactureCodingIndex: 1
VehicleManufacturerDiagnosticIndex: 1776
FunctionalSoftwareVersion:005.066.006
ECUHardwareNumber:0000006953783
C-Tunner
SystemNameOrEngineType:18758
VehicleManufactureCodingIndex: 4
DateOfManufacturing:28:06:2004
VehicleManufacturerECUHardwareVersion:5
FunctionalSoftwareVersion:005.014.000
ECUHardwareNumber:000004131580
C-ASK
SystemNameOrEngineType:18757
DateOfManufacturing:25:06:2004
VehicleManufacturerDiagnosticIndex: 2560
VehicleManufacturerECUHardwareVersion:66
FunctionalSoftwareVersion:005.019.000
ECUHardwareNumber:000004130747
C-Gateway
Thank you!
ECU List:
C-Application
C-Host
C-Tunner
C-ASK
C-Gateway
Thank you!
My Ride: G30 M550i
Model Year: 2018
I think the MKIII and MKIV nav designations are from pre-iDrive systems.
I don't think I've seen anything that references the E60 to those older version identifiers...
AFAIK BMW E60/61 instead of MKIII and MKIV has CCC.
Hi,
Thank you for the replies. So what is the version that my car has? CCC? It is a E61 from August 2004 with the system information i posted... Where can i find more info about this? Are the v25 or v26 software updates appliable?
Thank you!
Thank you!
My Ride: G30 M550i
Model Year: 2018
The only software updates that are available for your nav are the ones contained in the "CIP" releases by BMW. I don't think you can update the nav systems the same way you could on the E39 or other models.
The CCC system handles much more than just navigation so if I were you, I wouldn't mess with updating things yourself...
Originally Posted by fcc' post='197684' date='Nov 13 2005, 06:49 PM
Hi,
Thank you!
Thank you!
Rudy is right as usual
.The only "upgrade" you can do by yourself is the new release of DVD MAP Nav.
Currently for NAV Pro Europe there is 2006-1
jcolley
Aug 1, 2016 06:48 AM
Wonky
Apr 12, 2016 08:15 PM
Bank$hot530
Sep 16, 2015 01:28 PM
