MIRO M6 Replica Vibration Issue
I'm not sure exactly which M6 wheel brand you purchased but from my experience with M6 wheels in the low offsets used by the 5series the wheels come in a 74.1 centerbore. The 60 uses a 72.56 centerbore and would require a hub centric ring per wheel to convert the 74.1 to 72.56. Some vendors sometimes forget to include that with the order or even the end user is not aware of this and forget to install them. Try that out and see if it helps with your vibration issue.
My Ride: 2004 530i
As PTL pointed out, you should try putting the OEM wheels on to eliminate other non-wheel related issues. If that's clear, then you might want to consider another set of hubcentric rings. Sometime those can be an issue. GL
SORRY FOR MY BAD ENGLISH!!!!!!!!
I HAVE THE SAME PROBLEM BUT I CAN NOT TO FIX IT AND I TRY FOR TREE MONTHS!!!
I BUY AND CHANGE MY 19 INCH WHEELS WITH A BRAND NEW 19 MIRO 935 MODEL,I INSTALL THEM WITH ALL 4 HUBCENTRTIC RINGS AND WITHOUT ANY MODIFICATION BECAUSE ARE FITING EXACTLY AND WHEN I START TO DRIVE I FEEL A VIBRATION ON MY STEERING WHEEL JUST WHEN THE CAR RUNNING,I MAKE THE BALANCE FOR 4 TIMES AND ONE TIMES WITH HUNTER BALANCE MACHINE , I CHECK THE TIRES AND EVRETHING ITS OK,HONESTLY I DONT KNOW WHAT I HAVE TO DO? I CHECK THE FORUM AND SOME PEOPLE ARE SUGERATE TO MAKE THE ALINGMENT BUT THIS STEEP NOT REZOLV THE VIBRATION PROBLEM 90% ,MY QUESTION ITS IF SOMBODY KNOW IF I NEED TO INSTALL THE WHEELS WITH SPACERS OR I'M thinking TO CHECK THE FRONT LOWER ARMS W/BUSHINGS MAIBY SOMNTHING ITS WRONG... ???
PLEASE LET ME KNOW WITH ANY OPINION ARE WELCOME !!
PS MY TIRES ARE : FRONT-245/35/19
REAR--275/30/19
REAR--275/30/19
I BUY AND CHANGE MY 19 INCH WHEELS WITH A BRAND NEW 19 MIRO 935 MODEL,I INSTALL THEM WITH ALL 4 HUBCENTRTIC RINGS AND WITHOUT ANY MODIFICATION BECAUSE ARE FITING EXACTLY AND WHEN I START TO DRIVE I FEEL A VIBRATION ON MY STEERING WHEEL JUST WHEN THE CAR RUNNING,I MAKE THE BALANCE FOR 4 TIMES AND ONE TIMES WITH HUNTER BALANCE MACHINE , I CHECK THE TIRES AND EVRETHING ITS OK,HONESTLY I DONT KNOW WHAT I HAVE TO DO? I CHECK THE FORUM AND SOME PEOPLE ARE SUGERATE TO MAKE THE ALINGMENT BUT THIS STEEP NOT REZOLV THE VIBRATION PROBLEM 90% ,MY QUESTION ITS IF SOMEBODY KNOW IF I NEED TO INSTALL THE WHEELS WITH SPACERS OR I'M thinking TO CHECK THE FRONT LOWER ARMS W/BUSHINGS MAIBY SOMNTHING ITS WRONG... ???
REAR--275/30/19
REAR--275/30/19
My Ride: I have a 2007 Black Sapphire BMW 530i with SMG. It has the auburn interior, has PDC, Sports Package, Premium Package, rear automatic sunshades with manual side sunshades, 35% black tint, Upgraded angeleyes from Angelibrights, and Logic 7 Sound System
So I put the stock wheels back on with brand new runflats and it drives so smooth now. No vibration at all. I got the rims checked and none of them are bent...so I am assuming it is either the tires that were bad or the hubcentric rings didn't do shit.
Look in the classifieds for 20 inch miros going really cheap lol. And I will let the new owner know of the problems I had with the wheels.
?I try all the hub centric ringsand after that i think im gone try to put some HUB CENTRIC WHEEL SPACERS but i dont know how many mm on the front and rear ?? do you know? i try two different hub centric rings,like metallic and aluminium and the vibration its the same!!
please let me know !!
thnks
thnks
gurp99
05-09-2015 08:57 PM
