Merging 2 DVD maps
I?ve just purchased the 2012 map from BMW (I think it was waste of the money) and I really don?t see much difference between 2011 and 2012. As far as mapping guidelines using new Tom-tom software, I think it is horrible at least in Dallas area. Going from Fort Worth to DFW and via versa routhing is horrible. The 2011 routing concept was far better than 2012 version map.
Anyway, the question is both DVDs are fairly small, maybe less than 8GB togater. I was wondering if there is way you can burn these two DVDs on one dual layer DVD.
I made the copies from the DVDs and added the speed cameras and speed traps from my 2011 DVDs works great but still one DVD is about 4.3GB and the others lest than 4GB. I play around to see if I can merge these two DVDs but no luck.
Any information would be appreciated.
I can tell you so far I have not impressed with new 2012 map. Don?t waste your money on it
its not easily doable because the mapping data itself has been split. The EU is now on 3 discs as opposed to 1 disc until 2010. I suppose BMW had massive issues with the dual layer discs so now only sells the maps on single layer discs.
ucsbwsr
09-19-2015 10:58 AM
