Mechatronic solenoid replacement
My Ride: 2008 528xi (Silver)
Yes, you should via inpa. You can forsure drive without a reset, but it is best to reset since the transmission can learn the new status of clutch pack wear and how everything else is working.
My Ride: 2004 BMW E60
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
i have INPA but i dont know how to use it, i tried looking online for pdf instructions on how to use it but i found nothing
1.ignition on (engine off, you should see your fuel level gauge move to its normal value)
2. Open INPA
3. e60 -> Transmission -> Gearbox Control Module GS19 -> Activate -> Reset adaption values
2. Open INPA
i replaced my solenoids and gaskets,filters etc. and im getting a code saying solenoid d(shift lock) or solenoid D circuit low does that mean? i didn't drive it has yet or anything its still on stands haven't yet reset tranny adaptations do you think that might be tha problem?
socale39
09-05-2023 08:30 AM
pcy
09-12-2021 06:55 PM
