Mechatronic sleeve replacement
My Ride: 2008 550i Alpine White
I got quote from an indy for $870 to do the mechatronic sleeve. Is that a good price? I've been getting the tranny slam and delayed reverse gear. It only happens when the engine is cold.
Thanks guys!
Thanks guys!
My Ride: 2004 BMW 545i Silver,Gray, Metallic. Blk Dakota leather. Nav. Heads up disply. PDC. Pro logic 7 sound. 35% tint.
Mods. MTECH body kit. OEM trunk finisher and M5 spoiler.OEM 166 wheels. Blk and wht CF Roundels.
Orion V2 AEs. LCI taillights with Ricky effect. LED interior lights. LED license plate light. HID fogs. Smoked LED side markers. White cluster mod. Coding. RPI scoop & BMC filter. Gloss black OEM grills.CF interior trim. B&B exhaust.
I got mine done for $550 at a reputable indy shop. Therefore I would say $870 is very high.
I believe that is around what the dealer quoted me.
Shop around!
Shop around!
My Ride: 2004 Dinan 545i, Titanium Metallic Silver, 2007 Dinan M5, 6sp, Silver Gray Metallic
I think that is high, are they replacing the fluids as well? New fluid from the dealer is around $200.
The price is for new sleeve, pan, and filter. Is that still too high? It's the only reputable indy near me and its already an hour away. My only other option is the dealer. I will call them for quote tomorrow. Thanks guys!
My Ride: 530i
Engine: M54
Oil change kit for 6HP19/21
service kit (pan/filter, fluid) is $238. sleeve is another $16. Seems high to me unless they're changing out the fluid too. They'd be silly not to.
My Ride: 2005 545i sport package
I would agree that the price is high. Especially if they are re-using the fluid which it sounds like they are. I paid 733 for mech, sleeve, filter/pan and new fluid. The dealer quoted me around 900 for same. Not sure which part of NJ your are in but I had mine done at Bavarian Specialties in King of Prussia Pa. It may be worth 140 bucks to drive down and have it done there. And they give free loaners much to my surprise.
My Ride: 2006 530xi w/Sport, Premium, Cold weather. Silver Gray Metallic, Black Dakota leather interior.
If that is an indy I would say it is high. I got mine done at the dealership for about 730. Which did include fluid and filter.
Got a call from the shop today he said he'll top off the tran fluid for now and see how it runs. He pointed out the fluid was low. The shop is MD motorwerke in somerdale nj. If any members here been to them and have any feed backs I'll appreciated.
Eventually you will have to change the sleeve if is is leaking. When you drop the car off, take a look at the sleeve to see if oil is running out of it. It's located on the passenger side towards the back of the transmission about a 1/3 of the way up.
He said there were no leaks from the tranny so therefore he's going to top off the fluid. Although, I found engine oil leak in front of the engine. Mechanic said its the oil pressure switch. Taking care of that first. I'll update on the tranny issue. Thanks Vapiano
