maybe a big problem?
Old 03-01-2009, 01:24 PM
CWS530's Avatar
Originally Posted by tiangco.a' post='804738' date='Mar 1 2009, 03:51 PM
Ok so I did the test and it seems to grab just fine...the back of the car bounces just like you said. So just so I was clear this is what happens. If I'm driving normal in 2nd or 3rd gear. My rpms are at 3000 and then I put the gas to the floor with my foot completely off the clutch of course. It's will rev and still move and then the rpms go back down a little and Then it starts to really move as it normally should.
The fact that your foot is not on the clutch pedal has nothing to do with it, rather the internal parts are slipping. GL with the fix.
Old 03-01-2009, 01:52 PM
Richard in NC's Avatar
I thought my E39 M5 clutch was toast after I accidently slipped it under power a few times. It would not hook in a mid RPM 4-5 shift at any thing more than light throttle. I hear this is a more likely symptom of a "glazed" clutch than coming off the line.
I just drove very carefully and without "getting on it" for a week and it seemed to heal itself. I drove it for 5000 more miles but traded it before spending the money on a new clutch. I assume BMW replaced it re the CPO process before the next owner but you never know.
Old 03-01-2009, 02:24 PM
JLinardi's Avatar
When you pull off in 1st gear do you have to have quite high rpms just to get the car moving (for example it feels as if you are pulling away in 3rd gear rather than 1st?), otherwise it stalls? A classic sign of a worn clutch plate. Also as you change gear is there any grinding sound as if the clutch is not engaged properly?
Or do your problems only happen under acceleration when the clutch is NOT depressed? In your example you say you are cruising at 2000rpm and then you accelerate hard and the revs drop (am I right?).
Old 03-01-2009, 02:29 PM
craigm1841's Avatar
you need a clutch, no doubt
Old 03-01-2009, 02:34 PM
JLinardi's Avatar
Ah after reading this I have better understanding of the problem. What happens is you press hard on the gas and the revs shoot upwards? Then they drop back to normal and the car begins to accelerate? So basically when your accelerating it feels as if your accelerating with the clutch pedal slightly depressed? If that is the case then yes it is your clutch. In your 1st post I thought you meant that when you accelerated the revs went DOWN.
How long have you owned the car? WHoever had it before you obviously didnt drive it properly!!
Old 03-01-2009, 03:51 PM
tiangco.a's Avatar
No i dont have any problems at all starting off or anything...it grabs fine in every gear...its only when im already in a gear and then accelerate harder than normal that it would rev and then drop...while its reving the vehicle is still accelerating a little.
Old 03-01-2009, 03:56 PM
tiangco.a's Avatar
oops sorry for the misunderstanding. and im thinking the same thing...all of my previous cars have been standard and i have no problem at all with driving standard. Ive done a burn out maybe a total of 4 - 5 times...Gee it seems everytime i fix something, something else goes wrong!
Thanks everyone, it will get checked out tomorrow by my mechanic...at least i get cost on parts
Old 03-02-2009, 01:44 AM
Egypt_525i's Avatar
My Ride: 2008 525i LCI - saphire black on black dakota leather, dark poplar wood, moonroof, cruise control, electric seats with memory, nokia 6230i bluetooth + cradle, rain sensor, A/C with extended features, extended lights package, PDC, rear power sunshade, AUX Jack, steptronic, M-Tech steering wheel, 10 Airbags, smokers package, DSC, interior and exterior mirror with anti-dazzel function, business radio; power folding mirrors Mods: iPOD (OEM), BMW OEM floor mats, BMW OEM trunk mat, ///M Aerodyamics kit (OEM), 18" rims style 184 (OEM), 245/45 R18 93Y Contisport, ///M boot-lid spoiler (OEM), OEM Headlight washer system Future Mods: Solaris Invisibulbs - Amber Flash all-round; LED interior kit; LED License Plate; The Mrs.: 2009 e90 320i LCI - Carbon Black, Beige leather interior, Dark Poplar Wood, moonroof, cruise control, electric seats with memory, nokia 6233 bluetooth + cradle, extended lights package, rear power sunshade, NEW I-DRIVE with HDD + 2USB Slots +AUX Jack, steptronic, DSC, Smokers package, business radio Mods:BMW OEM floor mats, BMW OEM trunk mat The cars were manufactured in Egypt! :)
Originally Posted by tiangco.a' post='804452' date='Mar 1 2009, 10:59 AM
So after finally driving in dry road conditions I have encountered a problem. Say for example if I'm in 2nd gear cruising say at 3000 rpm. If I hammer on my gas it will rev for about 750 rpm and then go...I have a 2004 545i 6spd. So basically I'm just wondering if any of you have encountered this. I plan to take it to my mechanic on Monday by it's bothering me so just trying to get it out.
+1 on the clutch kit,
another way of testing is try to drive off on 3rd or 4th gear, if it does not accept, its a definite clutch kit...
Old 03-02-2009, 05:53 PM
tiangco.a's Avatar
Ok so it's been diagnosed that I do need a new clutch. I was looking today and could only find an oem one. If you guys know of any aftermarket good clutches that can support more pressure please let me know. Thanks
Old 03-02-2009, 05:58 PM
craigm1841's Avatar
oem should suffice. i wouldnt go nuts buying an aftermarket clutch. you will spend a lot of money and your car will be miserable to drive in traffic and you will have NO added benifit over an OEM @ stock power. what you may be interested in looking into is an OEM spec aftermarket clutch for the purpose of saving $$
Kasmo
05-07-2019 03:30 AM
E60Japanese
03-23-2015 05:23 PM
browellm
04-09-2004 08:48 AM
Mark-Yorkshire
The Competition
03-01-2004 02:12 PM
jckrauskopf
02-25-2004 10:42 AM
Quick Reply: maybe a big problem?
