Maximum Negative Camber
can't answer your question but can provide you with the setting on my car which is -1.8 degrees and still the tread contact is outward to the fender. i did not have my alignment done at the dealer, but was told that the rear needed to be done first [before the front]. i believe the machine was a hunter laser...gonna check with the shop and possibly have them corrected to more vertical.
i have not followed up with the shop that did my alignment. however, will check the tire tread depth since installing the tires 01/12 [about 3k miles]. i replaced the tires [4] due to rear wear and camber issues.
PelicanParts.com
07-23-2015 12:29 PM
