Lowering 2007 550i
Hi there,
I am getting new wheels for my 2007 550i to replace the stock 17 inch rims - which I just turned into my winter wheels.
I plan to get summer configuration:
front - 245/35-19 inch rim
rear - 275/30-19 inch rim
I want to lower the suspension as well.
I found H&R Springs with these specs:
Sport Spring E60 w/o self-leveling which should lower the car about 1.2-3 inches
however, I believe my suspension is self-leveling (e60) - unless I am mistaken.
My questions are:
1. What spring manufacturers and type would you recommend
2. Can I go without the self-leveling option? Is is better to keep the self-leveling suspension? Are there springs compatible with self-leveling suspension?
I don't want super racer springs, merely an improved suspension that would lower my car 1-1.5 inches and inmprove the handling a bit. Will I need to replace the sway bar as well?
Any help is much appreciated.
-Daniel.
My questions are:
-Daniel.
My Ride: 2015 535D M Sport
Do you have ARS (Active Roll Stabilization - comes with the Sport version)? If so, you can't make it handle any better and I doubt you could even find springs for it.
Ars helps eliminate the car leaning as much during turns, the system offered on the E61 is a leveling system that levels the car when you have heavy loads in the boot.
My Ride: 2008 550i DINAN
Engine: V8
I found the H&R Springs to be too stiff of a ride in my old big e38 *95 7 series. I put Eibach springs on my 01 e38 and found them to be MUCH nicer. While this doesnt speak directly to the 550i, I think the H&Rs will be stiffer in general than Eibach.
After some reasearch and talking to an ex-BMW tech, the self-leveling suspension is only on the Touring/Wagon models. So no self leveling. I don't have the sport package, then I am assuming I don't have ARS as well. I agree, it would not make much sense to change the springs on the sport package suspension. Mancho thanks on the feedback on Eibach vs H&R springs - leaning towards the former as well as I do a lot of downtown city driving and the roads a full of potholes.
How about offsets for the wheels, is it wort it to offset the wheels bit more for looks and/or better stability?
Thanks
Thanks
Nickalitis
05-18-2015 07:48 PM
5fanatic
04-27-2015 04:50 PM
