Low brake fluid -warning
As brake pads wear the brake fluid level may get low enough to trigger a warning. Check level and add correct fluid or get to dealer for a top off.
My Ride: 2004 545i 6spd Man, 19' Breyton Wheels, Ipod Install, Parrot Bluetooth, AC roof and Trunk Spoiler
Originally Posted by rudeja' post='514865' date='Jan 7 2008, 07:29 PM
I get the same light, can you use regular brake fluid, or does it require a specific one from BMW ?
Make sure no fluid touches the paint! If it has been over 2 years, the fluid should be replaced anyway.
