Lost Data ... had to reset!
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
This is now a reacurring issue.
Early yesterday AM I fired up my ride. The Active Steering was ?initializing? and was disabled. After 5 or 4 engine cold re-starts the AS worked.
And then much saved info was found to need reset. Clock and date, accumulated MPGs and average velocity. Damn, if I wasn?t saving data for a 1000 mike check on puter v actual mileage.
All this the second time. First time in shop my SA said they updated my progman and that would fix my problem. It did not.
A related issue is the distance bars on the Active Cruise are erratic after driving an hour or two using the AC. The SA said they could not find this problem. Seems like someone programmed that feature and should be able to establish what keeps the bars active. This, too, continues to annoy!
Any thoughts on all this before I head back to the dealers shop?
Thanks, sixcard
Thanks, sixcard
My Ride: 2004 550i - AS, SP, CWP, Nav, L7, Rear Sunshades, PDC, Comfort Seats
Thanks, sixcard
Thanks, sixcard
Originally Posted by GP550iSport' post='571500' date='Apr 30 2008, 09:39 AM
I have had similar issues with lost data and deactivated AS. I can't speak for ACC. Do you receive the a message at start up, Increased Battery Discharge with a picture of a car on a fork lift? I have a post regarding this. You can do a search, topic number 53777.
I did however take the car in and they found some problem with the instrument cluster. A new one [replacement] is on order.
Some how I could not dig out your topic 53777.
Vman33
Mar 14, 2022 04:43 AM
ucsbwsr
Sep 19, 2015 10:58 AM
Igor55
Buyer & Seller Feedback
Aug 20, 2015 11:45 AM
