Losing confidence in grip
My Ride: 2005 BMW 525D M-SPORT // Grey // SB attached
I am losing confidence in the grip on my e60.
The tyres do not worn out and I have not put any waxes on the base of the wheels.
But when I corner (semi-hard) the car slips and I ened o quickly correct it.
Anyone know if this is normal or maybe I am pushing it too hard ?
How do you find the cornering is in your m-sports ?
My Ride: 2008 M5, Silverstone II/Black
What tyres have you got? Which end slips (i.e. are you getting oversteer or understeer)? And has it always been like this, or just since the weather got cold? It's not just since your Sprintbooster was installed is it?
My Ride: E60 530d M-Sport
I have run flats on my car atm ( came with the car ). If I push hard in a long sweeping corner or on something like a large roundabout etc all I get is gentle understeer as a warning, if the DSC/DTC is fully deactivated etc I can provoke some oversteer at will with the throttle and steering, nothing happens suddenly tho, and the understeer always comes first giving plenty warning of impending doom if your overstepping the mark.
The speeds im talking about many would consider as extreme and very near to the limit, or indeed beyond the limit, if your experiencing anything different in every day driving or just having a "bit of a blast" moment you have serious problems with either your car, or your technique
( dont mean that to sound rude, just being honest and covering all bases
I have the contis on the front and I know no one runs these but
Michelin Pilot HX MXM4 on the rear. The Michelins are only good if
you run in a warm climate and I have a hard time breaking them
once I get some heat into them.
I would think you must still have the run flats on and should consider
switching them for some high rated summer or winter tires and you
should see a dramatic improvement in the grip
Originally Posted by Phantom Mark' post='742166' date='Dec 10 2008, 12:31 PM
Dont forget this time of year things are massively exaggerated by the weather eh ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Thanks guys - really helpful as per usual !!
I havn't really had the chance to grab this chassis by the scruff of the neck properly yet, cos of the weather of course, but the times I have played a little the immense torque makes the rear end go all over the place if you dont use your head in conjuction with the throttle lol, even with the Aids switched on the car squirms around all over the place if you get carried away ( albeit briefly )
I have never experienced this car with any other tyres, and can only compared the chassis with my E46 320d which I recently part ex'ed for this car
, the E46 was positively tame compared to this in terms of getting the power down lol
So anyways yer, please accept my opinions on "my car" as a casual one and only having had somewhat of a limited but exciting play once or twice
Mines a sport not m sport but have 18in conti 3 non run flats / koni fsd's with sport springs / cut down front bump stops and find the grip levels superb. As my e60 came with stock sport dampers and springs with dunlop run flats the grip levels and ride quality were far from desirable.
My Ride: 05 530D Sport E61
I had left changing my tyres a little late and there was inch of snow on the drive, there was no way the standard tyres would get up my drive. 1 hour later and 4 winter tyres later not even a touch of wheelspin. Winter tyres are honestly that good!
