Looking for resolutions to some issues
Hey guys... maybe one or more of you have had the opportunity to tackle some of these issues (duly posted on another forum for max. results):
1. I am not too short, nor too tall, but my seat feel lower than I'd like. I can't raise it any higher.. I need another inch or two, that's all. my e39 went higher, as did my x5... anyone have a height adjustmet issue as well? any solutions proposed?
2. the volume knob on the radio mutes it, only. every time i turn the car on, the radio/cd comes on.. even if it was muted before.. how do i turn the radio OFF?
3. is there an I-drive screen I can default to after hitting the accept button, for example, entertainment?
4. RDS for NAV - does anyone have this working?
5. has anyone else noticed that with 13.2.3 software, or other v.13 upgrades, active steering feels a bit tighter, not so loose?
6. I love this car! anyone else have this problem?
thanks
thanks
Originally Posted by wassy' date='Oct 20 2004, 09:46 AM
1.? I am not too short, nor too tall, but my seat feel lower than I'd like. I can't raise it any higher.. I need another inch or two, that's all.? my e39 went higher, as did my x5... anyone have a height adjustmet issue as well?? any solutions proposed?? The seat only goes as high as it can.? I'm 5' 11" and have my seat almost all the way up.
2.? the volume knob on the radio mutes it, only.? every time i turn the car on, the radio/cd comes on.. even if it was muted before.. how do i turn the radio OFF?? I think you can turn it off by pushing the volume knob in to the left of the CD slot.
3.? is there an I-drive screen I can default to after hitting the accept button, for example, entertainment? Unfortunately, no, not that I know of.
4.? RDS for NAV - does anyone have this working?? Doesn't work with Nav and 13.2.
5.? has anyone else noticed that with 13.2.3 software, or other v.13 upgrades, active steering feels a bit tighter, not so loose?? Yes, my wife noticed it too.
6.? I love this car!? anyone else have this problem?? Drives, well.? Electronics, stink.
thanks
thanks
[snapback]47077[/snapback]
Hey Wassy I cant help you with Number 1. But with Number 2, 3, and 4 it's all related to software version 13.2.2...
2. The mute bottun works the way you described it. Even though you might have muteed it before you shut down the car, when it is turned back on, the radio unmutes automatically.
3. iDrive works like any OS, and you cannot alter its startup settings to take you directly into a Menu option. It will always come to the default menu.
4. After getting the software upgrade to 13.2.2 you will lose RDS if you have Nav.
5. My active steering hasn't changed, perhaps someone else can comment on that.
6. Drives well! Electronis just need some more upgrading and top-notching.
Hopes this helps.
Hopes this helps.
I appreciate the responses, and hope for more... even the taller guys have the seat all the way up.. maybe there needs to be some inserts under the rails put in, or some other adjustments.. I need it.
andy
andy
Originally Posted by John W' date='Oct 20 2004, 12:20 PM
my radio stays muted when I start back up. you saying that's going to change if I upgrade to v. 13?
[snapback]47155[/snapback]
andy
andy
[snapback]47105[/snapback]
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
[snapback]47287[/snapback]
[/quote]I have not tried another e60, yet, but I have a sneaking suspicion they are all the same.. why? because the passenger seat is the same height as well..
cushion won't work.. not sightly..
[snapback]47314[/snapback]
![Innocent](https://5series.net/forums/images/smilies/imported/innocent.gif)
DavaiLave
08-02-2022 02:16 AM
Lomag
Site Comments & Suggestions
79
08-06-2004 04:02 AM
