locked my key in trunk
Old Oct 13, 2021 | 06:53 AM
Dollface's Avatar
My Ride: 550i
Model Year: 08 550i
Default locked my key in trunk
so I've locked my blade key in the trunk. I have the fob, but the trunk button doesn't pop the trunk and the lever up under the dash doesn't work the previous owner snipped the wiring harness that goes to the rear electrical. I do not have a ski bag and believe the seats don't fold down. what do I do?
Old Oct 13, 2021 | 07:24 AM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
This might be specific to the touring models, but if I unlock all the car doors (either with the fob or the center console button) then the button the on trunk is activated and lets me open the trunk. Not sure if it's the same on sedans. Are you aware of the trunk unlock button on your fob not working previously?
Old Oct 13, 2021 | 07:34 AM
Dollface's Avatar
My Ride: 550i
Model Year: 08 550i
the fob hasn't opened the trunk since I got it. under the interior paneling on the right hand side I found my wiring harness with multiple wires cut. I'm not sure if the trunk is getting the message from the brain to unlock or open it
Old Oct 13, 2021 | 11:51 AM
militarydave's Avatar
My Ride: 09 BMW 528i - N52B30 Engine, 218k miles and counting. 2022 228i Gran Coupe. 18k miles and counting
Is your battery disconnected? The other option my be to remove the backseat (it's really easy) and see if you can access the trunk that way. What year/model do you have (example: 2007 525i)?
Old Oct 13, 2021 | 03:15 PM
donpb's Avatar
My Ride: '06 530i N52
When I locked my key fob in the trunk, I had a locksmith pick the trunk mechanical key cylinder. Two locksmiths were unable to gain entry into the vehicle cabin.
Old Oct 14, 2021 | 12:23 PM
hoser's Avatar
My Ride: 535i
Do you only have one key blade? You can also have your dealer cut another key blade from your VIN. I think online sources will do it as well (save $$).
scottalexander
Apr 15, 2018 11:36 PM
BlueHorse
Jan 10, 2011 08:27 PM
jchris
6 Series Discussion
Apr 9, 2009 11:48 AM
Ruf930
Nov 15, 2005 11:16 AM
eugeneloke
Nov 10, 2005 06:53 AM
