at the light
Old Jan 11, 2014 | 04:50 AM
ras545i's Avatar
My Ride: Black, sport pkg LA style rims, sun shade on rear passengers and rear glass, 6disc changer,
Default at the light
Hi all,
I recently purchased a 04 545 with 114K on it and have been reading/searching thru the forum, but havent came across with anyone posting any info about these two issues. Any assistance would be greatly appreciated...
The two issues that are driving nuts right now are
1. its starting to make this rattling sound from the front passenger side. This happens if the AC is off. It first started only when the vehicle is in drive or reverse, but now even while park. So far if it happens when stopped at a light I have to turn on the AC or MAx cool.
2. while in park if i turn the wheel to the left, i get this ticking sound like somethings loose
it also happens if im turning into a parking lot and theres maybe an slight bump, i get a knock sound...
im about to get me an extended but wanted to knock out these minor issues first....
By the way did I mention this cars a beast!!!!!!!
Old Jan 11, 2014 | 10:57 AM
jc545i's Avatar
My Ride: BMW 2004 545i sport
Bro I been looking for this same problem and nobody can figure out it im gonna have a year now and still can figure it out im lost ???????
you are right about this car its a monster
Old Jan 11, 2014 | 11:22 AM
ma_tty_d's Avatar
My Ride: E60 01/04 545i - 19" Alloys
Hey ras545i,
I am no expert in cars but from my experiences I think I can help you:
1 - is there something rattling? the rattle could be caused by the vibrations from the engine at a lower RPM causing a loose bolt or panel to rattle. When in drive and the hand brake on, just press on various panels around the area the noise is coming from and see if it stops
2 - this sounds like a CV joint, my car is doing the same. mine 'clicks' every half a steering wheel rotation in most cases, sometimes it doesn't, but mainly when I'm driving very slow, or pulling into the garage it does it. It could be the steering column from what I've read in some posts, but if the noise is coming from the front end of your car its possibly the same issue as mine.
Hope this helps,
Matt
Old Jan 11, 2014 | 02:06 PM
H F's Avatar
H F
My Ride: 2005 545
I was thinking possibly bushings or the ball joint on the tie rod end.
DavaiLave
Aug 2, 2022 02:16 AM
BMW565
Nov 6, 2017 06:03 PM
thesalboy
Apr 8, 2015 09:13 AM
rizwan1377
Apr 5, 2015 05:22 PM
Stranger12
Apr 5, 2015 10:42 AM
