Leaking Transmission Pan
My Ride: BMW E60 530i
Cheers,
One thing, the 6HP19 pan has the integrated gasket aswell, or am i wrong? So how would I get them to replace the gasket when it comes stuck to the pan?
Will just redoing the bolts in the sequence and correct torque be sufficient?
Hmmmm...you could get lucky re-torquing the bolts. You have a problem. The amount of oil in the pan exceed the pan volume. What that means is you cannot take the pan off and start over. You cannot unscrew all the bolts enough for everything to be very loose. All the oil will come out. You might be able to very lightly unscrew all the bolts, while making sure the gasket is still in contact. Then retighten them in sequence and with a torque wrench. Be prepared for failure (as in fluid comes out).
My Ride: 530i
Engine: M54
the groove in the pan. You can most definitely replace just the gasket. I know; I've done it.
OP, trying loosening and retightening the pan bolts to proper torque spec in the proper sequence. If that doesn't do it, you may have a defective gasket.
Thanks KyleB, always a great help.
I'll try positioning to the workshop Monday, I have a feeling they will disagree etc but will try how it goes.
I don't have the tools to do it myself etc nor am I comfortable doing so. So should I just buy the repair kit (comes with the pan and bolts and gaskets) for roughly $100 (sourced myself)? and get them to install the new pan, gasket and put in new bolts?
If this ship did the work and it is leaking, then don't buy anything...take it back to them and tell them to fix it. The transmission is fitted with a plastic oil pan and doesn't need a metal pan. That's all there is to it. They screwed up something -- or possibly there is a defective part. But, the repair shop needs to fix it.
Thing is that I bought all the parts. They only did the labour. If it's leaking cause Of the pan then it's not their responsibility (I assume) .Only if the bolts arent torqued correctly then yea?
So I'll just go back and get them to retorque and sequence the bolts first. Just got to find the diagrams again
My Ride: 2006 BMW 550i
and i would not bother with retorquing the existing pan. you might as well change it, while the car is up in the air.
ok mwaku, I understand your situation. If you don't feel comfortable doing this job yourself, maybe you should find a new garage to do the work and have them order the new pan. At least in this case, the new garage will be on the hook for the entire thing.
Dammit, should have just gone with KyleB, it was just the gasket that was 'compressed' and caused the leaking. Nothing wrong with the actual pan (sigh - i went and bought a new pan, gasket and bolts (bolts because i didn't change them the last time and thought might as well)).
Well pretty annoying, but leaking I think has stopped. I'm bracing myself for the gasket to leak again.. but if it does, atleast I know what to buy and to buy 'the best' i possibly can.
The current parts are from the US i got from eBay, and they used the brand Bapmic (didn't know until i received it).. I'm pretty sure my last one was Bapmic too... so im abit hesitant and worried is going to leak again. Hopefully not though..
pcy
09-12-2021 06:55 PM
