Leak on driveway
Old 02-15-2011, 12:20 PM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
Originally Posted by Will Greer
Same here. I actually got out for $109 including labor. It was the thermostat that had gone bad - how that results in a coolant leak I don't know, but I looked around on this forum and Bimmerfest and found a few other people with the same story. I was shocked at how cheap the repair was. First time for everything...
You paid $109 for a t-stat and install???? No fricken way! I was quoted at $490 for the same and had a BMW tech friend do it for $150... I think the t-stat and a couple gallons of BMW approved antifreeze would total more than $109 not even including labor... and the antifreeze will leak when the pressure backs up and the t-stat either stays open or closed...
Old 02-15-2011, 01:14 PM
Will Greer's Avatar
My Ride: 2005 545i
I know...amazing. This was with my independent all-import mechanic. I had purchased some coolant separately, so in fairness I should add the $25 I spent there onto the cost.
Old 02-17-2011, 11:48 AM
IceBimmer's Avatar
My Ride: 2004 545i Platinum Silver Metallic Gray Dakota Leather, Premium Pack, Premium Sound, Logic 7, Sport Pack, Navi, PDC, Sunshades, Cold Weather and HUD. 56k miles Feb. 2011
I took my car to an independent shop to inspect the car for coolant leaking. They found out the two hoses attached to the engine are leaking. They charge me $740.00 to replace the two hoses since many parts need to be removed in order to reach the hoses. Am I being rib off or this is true ?
Old 02-17-2011, 11:59 AM
nickolas_g's Avatar
I had the same issue. It was relatively clear. When I took it in it was a transmission hose that let the fluid leak out. Your tranny fluid IS clear. It is not colored like US cars. They fixed it under warranty. My car was a bit sloppy in shifting but not a huge difference. I would get it done immediately.
sxybeemr
06-20-2023 10:13 AM
Johnny B
E34/E28/E12 Discussion
12-25-2015 05:33 AM
abrookey
E60 M5 Discussion
09-22-2015 05:05 PM
subieworx
09-21-2015 01:19 PM
ST JAMES
09-04-2015 04:54 PM
Quick Reply: Leak on driveway
