LCI Business Navigation
Old May 31, 2007 | 10:04 PM
nicke60gre's Avatar
Originally Posted by diveleader' post='430590' date='Jun 1 2007, 08:56 AM
Very Nice
Very interested to see if the new nav disc works in the pre LCI Bus Nav system with the same feature set.
No it doesn't :thumbsdown: I have the same disk and I checked it on my previous Business Nav (with CIP 24)
Maybe ...in the future
Old May 31, 2007 | 10:05 PM
shakalliberec's Avatar
Originally Posted by nicke60gre' post='430224' date='May 31 2007, 06:50 AM
Just put the word "facelifted" in place of "LCI"
Thanks for clarification
Old Jun 1, 2007 | 08:32 AM
andy545's Avatar
Model Year: 2005
Engine: 545i
Originally Posted by timewa' post='430356' date='May 31 2007, 08:30 PM
Only the rods, and it looks fantastic. I don't use the auto position, but the "on" position which means that the lights are always on when I drive.
I really like the way the tail lights are dimmed slowly when I lock the car... first the center dims until it's off, then the rods slowly dim.
The bulbs are for braking (2 phases, hence 4 bulbs). The rear lights are the small white rectangles. All lights are very bright, and I wonder if they're not too bright to disturb people behind you (like the LED blinkers)
I was also interested hearing about this...timewa : are your daylight running lights activated in your settings ? and can you confirm the light switch position is in the second right position ?
Old Jun 2, 2007 | 02:05 PM
E60525d's Avatar
Anyone know for sure if the hardware for ths business nav has changed for the LCI? Is it a new MASK computer?
Old Jun 3, 2007 | 02:40 AM
timewa's Avatar
Yes, I do have the option "daytime running lights" enabled in iDrive. And I always keep the light switch in the 2nd position (not sure if the DRL option makes any sense now, as the lights are always on when the car is running).
I wanted to experiment a bit with these settings but have not yet done so.
One more comment on the LCI business navigation: It shows traffic jams on the map (white dots), even if they're not on your route! Cool feature.
Old Jun 3, 2007 | 08:46 AM
aybeesea's Avatar
If DRL functionality is enabled in an EU e60's iDrive then the DRLs are switched on at the "Auto" position (left/anticlockwise from "zero"/off).
ABC
Old Jun 4, 2007 | 05:48 AM
E60525d's Avatar
Old Jun 14, 2007 | 05:40 AM
big_ipaq's Avatar
What do you mean? In my pre-LCI business Nav with Progman 25 and older, I was using 2007-1 a lot. Just no maps, but works just fine.
Old Jun 14, 2007 | 06:36 AM
nicke60gre's Avatar
I meant that maps didn't worked
Old Jun 17, 2007 | 02:01 PM
mat xxl's Avatar
