Knocking noise steering wheel
My Ride: BMW 530D e60
![Arrow](https://5series.net/forums/images/icons/icon2.gif)
Hello everybody,
Sorry for my English (I'am French : Blush
, I have a little problem with my bmw 530d e60 2003.
A knocking noise appear when I turning the steering wheel.
video :
https://www.youtube.com/watch?v=2kBX...ature=youtu.be
The noise is coming from here :
![](http://i39.servimg.com/u/f39/18/44/06/19/10.png)
Another video with the knocking noise :
I try to apply grease everywhere but it's not working.: Barf:
Have you got ideas ?
Thanks a lot
video :
Thanks a lot
I hear that knocking noise on my E60 when I rock the steering back and forth while the car is standing still with engine off. I don't hear any noises while driving.
Hello, Yes I have the noise when I drive !
I have the noise Left side and right side( with the steering wheel) at the same position.
Ok, the lower portion of the steering shaft, but I don' find any mechanical slack
My Ride: 2006 BMW 550i
were the lower control arms replaced recently? if the bolts that hold the control arm bushing to the frame, are not really tight, they will shift back and forth slightly, causing knocking sound. it happened to me, when i didnt tighten the bolts enough.
Yes I replaced the lower control arm on September 2014 bot nothing change.
I can try to much more tight the bolts.
Is it complicated to replace the lower portion of the steering shaft ?
My Ride: 2008 528i, Black Sapphire, M5 front, 2piece Niche Touring II, Nitto Invo, H&R
Checking in - same problem here. No effect to the driveability of the car but still very annoying.
