Key specific settings
Banned
Originally Posted by SaintK' post='234481' date='Feb 3 2006, 07:34 PM
I'd try this, but NOT sure if it'll work. Try unlocking the vehicle REMOTELY (This is very importantl) and verify all the settings are for that key. Now close the door and lock the vehicle remotely with the key you want the settings copied to. If that doesn't work, well changing everything manually is an option lol. Also a little trick, if you unlock the vehicle mechanically with the key (not by remote) and change the settings and then lock it remotely it won't save the changed settings. Only if the vehicle is opened and locked remotely it will save the changes made.
