Key fob problem
A good friend of mine told me today that his key fob sometimes does not work. He does NOT have comfort access. He took car to dealer and they told him this was caused by his window tint interfering with the antenna. Has anyone on here had this problem? I call BS on this! His car was at 49000 miles when he went in so still under warranty but now he's out. I'm thinking maybe the battery in the fob. Can this be replaced? Dealer also said no, need a need key...
Yes, Luigi is right... this happens all the time especially for those who have metallic film all around. I bet you if he points the fob standing in front of the car (assuming of course he did not tint the windshield) the fob will more likely work then any other spot.
I asked him this and he says when it does not work it does not work. Windows down or up inside r outside car. I'll mention try getting in front of the car and see what happens.
My Ride: Alpine White 2010 535 M-Sport
My windows are tinted with no problem, so Im assuming a new FOB might be in order if he doesnt have a spare.
Yep the non CA FOB is a rechargeable battery that charges while being used. Its suggested that you drive at least 2 long drives a year with each FOB. The CA FOB also charges while driving but has a replaceable battery. Perhaps this battery has worn out. Does he have a spare FOB to try?
Engine: N54
I thought the battery could be changed but he was told by the dealer it can't. I was searching last night and I thought I had once read that a member here put something out about changing a non CA battery. He only has on FOB, when he purchased the car there was only one and the problem is intermittent. I would think if it was the tint or the type of tint the problem would be more consistent.
The fob can be cut open - I did mine with combination dremel and hobbie razor knife. Cut it open, locate the battery and replace it with another re-chargable ( I don't know which one), put it back together with hot glue, sand the edges smooth, paint the edge with black paint.
For my project is wasn't to replace the battery so I don't know which one but I have read of someone doing it. could probably replace it with a non-rechargeable button battery and just don't put it in the ignition slot. In that case, get one of those neoprene fob jackets to hide the cut scars and glue.
My Ride: 05 BMW 530I
Well I had a nice long reply but my computer messed up and I lost it. I would take a look at the website before attempting repair. I sent my key to this guy and he fixed all my problems. Make sure you look at the key fob hall of fame page too.
My Ride: 2014 535 Alpine White
Non comfort access keys have a rechargable battery inside if its acting up you need a new key or you can try a DIY battery change. Comfort access cars have a non rechargeable battery inside and have to be changed about every year to two years. Comfort access keys do not recharge and that is the reason for the removeable battery in back of the fob.
My thoughts now since he has only one key is to order a replacement and then perhaps try opening the old fob and replacing the battery. He told me yesterday that everything was fine and he had an engine over heat. Had car towed to dealer and the WP was replaced and at that time they competed the warranty recall for the battery. Car had like 49000 on it. When he collected the car that evening the fob did not work and the service guy told him to pull the fixed key from the fob to open the car and that the problem is caused by his window tint interfering with the antenna. it's still doing it but totally random... I find it a bit strange.
