Just purchased an 08 535i- 3k later engine kaput
Old 10-13-2013, 04:53 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
do you have a lift? if you do, then you can drop the whole engine/trans/axle assembly like the dealers do.
Old 10-13-2013, 09:22 PM
amg.pro422@gmail.com's Avatar
My Ride: 535i
Spent $300 today at harbor freight for a 1 ton engine crane, stand and low profile transmission jack along with some gloves, rags and (fine grain) walnut shells. Plan to clean intake valves on the engine I just bought. Should I try and soak the carbon buildup with a cleaner before blasting it or should I just use the walnuts....anyone know?
Old 10-14-2013, 12:50 AM
Only Bimmers's Avatar
My Ride: 98' 528i Manual07' 550i Sport
A walnut shell blaster doesn't require pre-soaking. However if you opt for a chemical, use Berrymans parts cleaner in the 1 gallon container. It is awesome stuff.
Reino550
05-19-2015 02:52 PM
TexaZ3
05-06-2015 09:54 AM
incoherent
04-15-2015 04:48 PM
2004_545i
04-08-2015 04:01 AM
dv8ed
12-24-2003 07:41 PM
Quick Reply: Just purchased an 08 535i- 3k later engine kaput
