Interior Noise
Old Aug 5, 2009 | 02:05 PM
atlarep's Avatar
Hi!
I have a BMW E60 530da, year 2004, with 137000 Km and i have a noise in interior of my car.
This sound disapear if i open a little the 2 rights windows of my car (only 0,5 cm its suffisant to the noise disappear).
I need help to resolve this problem.
Thanks a lot
Rui Peralta
Old Aug 5, 2009 | 02:12 PM
jprovence's Avatar
you could replace door seals.
Old Aug 5, 2009 | 02:24 PM
atlarep's Avatar
The door seals that you talk are the rubber that circumvent the doors?
Thanks
Rui Peralta
Old Aug 5, 2009 | 03:04 PM
vegadonovan's Avatar
If its like creaking sounds similar to the body of the car being flexed, then I supposed its the door seals ( the black rubber tube that goes around the door and also there's a rubber flap beneath the door) being dry or something. Give it a wipe down using rubber conditioners and check how is it. Some would suggest vaseline for longer lasting effects. The sound will come back after some time.
Dealers would stick a 3M friction tape to mitigate this issue near the door sills I heard. Try if it helps.
Old Aug 5, 2009 | 03:09 PM
kgmccarthy's Avatar
Originally Posted by atlarep' post='966725' date='Aug 5 2009, 06:05 PM
Hi!
Thanks a lot
Rui Peralta
This is a known problem. You can either replace the door seals or just put a little Vaseline on the felt material on top of the door seals. That should make the problem go away for several months.
Here is the TSB
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B510205g.htm
Vman33
Mar 14, 2022 04:43 AM
bestofthebest
Mar 28, 2016 02:47 PM
bestofthebest
Oct 2, 2015 03:21 PM
LILBZ3
Sep 27, 2015 08:06 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
