instrument cluster replacement...
Old 08-02-2012, 01:10 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Originally Posted by ETNav382
Lol yea, the cluster was great back in SoCal where the highway actually had lights on it but here in the middle of nowhere not so much, since the base here is about 40 miles from the nearest city really. That along with winter and fall darkness from 430pm til 7am, it's a little too much.
Why don't you just toggle it down and dim it?
Old 08-02-2012, 10:47 AM
ETNav382's Avatar
My Ride: 06 550i
Model Year: 06
I have, but I'm getting illuminated paddle shifters in the next month or so and the buttons on my sport wheel actually light up too. You cant really see that with the lights dimmed all the way. In all honesty, I'm just being a little picky.
Old 06-17-2018, 06:06 PM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
With all this talk about instrument clusters, have any of your had problems with the e60 instrument cluster audio speaker in the rear of the cluster?
When I turn the blinker on, I can not hear the blinker audio and I don't know if the blinker is on.
Is this a instrument cluster speaker fault, relay fault, wire, switch or ghost in the machine?
Anyone have a few guesses to get the blinker audio operational?
Old 06-19-2018, 02:15 PM
cmyachtie's Avatar
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
Originally Posted by digimurda
hi all,
i have a 05' 545i
the instrument cluster is shot, only certain lights on it turn on at times, which is kinda annoying...
i recently bought a used instrument cluster instrument cluster from a local salvage and I'm thinking about
swapping it with mine, only thing is my car has 80k miles on the odo, i was told the one i bought has 100k.
which mileage will show once i install the instrument cluster i purchased???
Just a little tidbit for you, when I got my 545 in 2012, my cluster was acting funny, like it was possessed, so I went out and got another cluster off eBay figuring my cluster was screwd as I was unable to fix it with either coding or whatever I was capable of trying with my INPA Etc. Suite.
I got the the replacement cluster and plugged it in and turned the key(did not start engine), as my problem was immediately showing up as the same with this as my original cluster so I immediately unplugged it and reinstalled my old cluster.
After 6 months of me screwing around trying to fix it finally went to my dealer and had them reprogram whole car and while I was waiting the tech came to tell me they needed to put in a new cluster.
I told them to forget it as I already had swapped the cluster and and had same problem with it so, he went back for another hour or so and car was fixed......EXCEPT for when I now read any faultcodes from N62 engine they all occur at 100000 mileage as my real mileage is still less at this point, however it is finally approached that number and am anxious to see if things will synch at that point.
Should point out though that my cluster mileage readings have always been correctly realistic, and no dot has ever appeared.
bbbamboo
09-17-2017 04:33 PM
16g-95gsx
11-12-2015 01:46 PM
Luie
10-06-2015 03:01 PM
bestofthebest
10-02-2015 03:21 PM
ianbmwe60
08-23-2015 03:20 PM
Quick Reply: instrument cluster replacement...
