Injector issues & Fault codes - help please
My Ride: 535d M Sport - Visibilty, Media, Logic7, Heated Comfort Seats, too many other extras to list
I had my 2005 535d (104k) on an INPA diagnostic machine today for a health check and a few things came up (which is to be expected for the mileage I guess):
We suspected a dodgy injector (or injectors) and a visual check of the injectors showed:
Now which injector (or injectors) need changing based on that screen shot? I would guess cyl 4 but that seems too easy
And where in the Midlands could I get them reconditioned as opposed to buying new ones for ?400 a piece? :shocked:
Also, the throttle actuator fault is the common one which apparently can stop one of the turbo's working - well in my case it has not had that effect, car runs perfectly well and pulls like a train. I test drove a few when i bought this one and this seemed no different to the others, it seemed more powerful than one that had 70k on the clock - and I can certainly confirm that both turbos are working fine. How much is the throttle actuator part to replace, if I needed to? That fault has occured 21 times between 40k and 101k but I bought it at 103k. Also, it seems to only occur when the throttle position is 0% (closed). Can this be right?
Last question is this - the car has been serviced from birth to 101k by the same supplying BMW dealer - it is now out of warranty as of Jan 09, however they should have picked up at least some of these faults during its lifetime and fixed under warranty. What are my chances of a goodwill contribution?
TIA
And where in the Midlands could I get them reconditioned as opposed to buying new ones for ?400 a piece? :shocked:Also, the throttle actuator fault is the common one which apparently can stop one of the turbo's working - well in my case it has not had that effect, car runs perfectly well and pulls like a train. I test drove a few when i bought this one and this seemed no different to the others, it seemed more powerful than one that had 70k on the clock - and I can certainly confirm that both turbos are working fine. How much is the throttle actuator part to replace, if I needed to? That fault has occured 21 times between 40k and 101k but I bought it at 103k. Also, it seems to only occur when the throttle position is 0% (closed). Can this be right?
TIA
My Ride: 530D M Sport Auto. Carbon Black with Beige Leather
Cylinder 2 and 4 both look suspect though still within tolerences. Does it idle a little lumpy?
Bet the dealer wont be interested as unless the car has been in for a specific fault which has re-appeared they wont see it as their problem. I doubt they do a diagnostic every time your car goes in for routine servicing.
Can't help you with the other bits im afraid.
The idle is fine 95% but once in a while you can feel a little 'skip', it happens very rarely though.
TBH, none of the faults found appear evident from driving it, I'm just trying to get ahead before something actually goes really wrong.
I'm not sure which INPA was used, it was a friend's equipment. Thanks anyway.
Originally Posted by Howitzer' post='967983' date='Aug 6 2009, 11:40 PM
wow. You might as well put some Greek text in here and ask for a translation.
(j/k
Originally Posted by mobilejo' post='968015' date='Aug 7 2009, 12:22 AM
Thanks for the help.
Originally Posted by 530DMSport' post='968023' date='Aug 7 2009, 12:36 AM
Might be worth adding some millers fuel treatment.. see if it sorts things out?
Originally Posted by mobilejo' post='968318' date='Aug 7 2009, 09:10 AM
Do you think that could get the injectors working a bit better?
thesalboy
Apr 8, 2015 09:13 AM
md750i
Apr 8, 2015 06:08 AM
linxuan
E39 Discussion
Mar 22, 2015 06:16 AM
