Info on "True" Speed and RPM Readings Please
#31
Originally Posted by Bokke' post='234796' date='Feb 4 2006, 04:38 PM
Znod - I found a stationary radar station on a nearby street, the kind that the city puts up for a few days to let people know how fast they are going...
..well anyway, I made a couple of passes to compare my HUD to the displayed speed and in all three instances there was a 3mph difference = HUD @ 39 & radar @ 36 / HUD @ 58 & radar @ 55 / HUD @ 65 & radar at 62....
...the last one a man walking his dog waived at me rather angrily to slow down
Cheers,
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Cheers,
#32
Cheers,
Cheers,
[/quote]
HUD and speed are identical!
#33
Originally Posted by Znod' post='234788' date='Feb 4 2006, 04:16 PM
As indicated, "I was interested in getting to ... the k/ph (kilometers per hour) menu and to the tachometer menu .....".
Above, I indicated that "at 3,000 RPM in first, my speedo showed 18 MPH rather than the correct calculated value of 16 MPH (with 30 MPH versus the correct 28 MPH in second, and 45 MPH versus the correct 43 MPH in third. Today, I also made observations on the digital speedometer getting 25 k/ph at 3k RPM (first gear), 45 k/ph at 3k RPM (second gear), and 70 k/ph at 3k RPM (third gear). Remember that both the analog and digital readings are subject to observatonal error although I confired each value reported multiple times. Starting with third gear we have:
"Analog" 3k RPM in third yields 45 MPH versus the correct calculated value of 43 MPH.
Digital 3k RPM in first yields 70 k/ph--which converts into 43.5 MPH--which is quite close to the correct calculated value of 43 MPH
Continuing similarly:
"Analog" 3k RPM in second yields 30 MPH versus the correct calculated value of 28 MPH.
Digital 3k RPM in second yields 45 k/ph--which converts into 27.96--which is almost identical to the correct calculated value of 28 MPH.
And:
"Analog" 3k RPM in first yields 18 MPH versus the correct calculated value of 16 MPH.
Digital 3k RPM in first yields 25 k/ph--which converts into 15.53--which is very close to the correct calculated value of 16 MPH.
Assuming that it is not coincidental that what I call the correct calculated values and the related digital values are so close, then all of the above lends credence to the idea stated above--that my Step is starting to shift at ... [correctly calculated values of] 28 MPH and 58 MPH and, consequently that the RPM's when it starts to shift are those in orange below."
(5,308 / 6,500(34.28769707) = 28
(6,170 / 6,500)61.10243456 = 58
As indicated earlier, these RPM's are atrocious. In this regard, it does not seem possible that the correct/digital values could be wrong while the analog values are correct--especially since the analog values are supposed to be determined using a "motor" and the digital values as inputs.
Still, there is a fly in the ointment. Given that I am not sure how the digital values are determined, it might be the case that both types of "correct" values suffer implicitly from, in effect, the same error--presumably caused by differing tire diameters. If the error is in the right direction and by the right amount, then the analog speedo could actually be correct. On the other hand, it could be farther off than suspected.
#34
#35
Originally Posted by grogan545' post='234490' date='Feb 3 2006, 10:44 PM
I would like to run some tests sooner but it is supposed to rain tomorrow and I will be busy Sunday.I do want to make my runs on my same test road to not introduce other possible factors for discrepancies.Also I will keep my GT2 at 10" rollout for direct comparison to original data.
#36
And:
[/quote]
I am dealing with the last point mentioned above to completely cover all the bases. I did not eliminate the quoted material above for continuity.
A mentioned, my tire diameter imples 807 revs per mile. The stock sport-package tire implies 814 revs per mile. If I assume 814 revs per mile, then:
There are 814 revs per mile given 275 / 35-18 rear tires.
At 60 mph one would do a mile a minute, or 814 tire revs per minute.
If the effective rear-end is 1:1, then a mile a minute would take 814 engine RPM.
If the effective rear-end is 2.3322:1 (as in 6th gear), then 60 MPH would take 2.3322(814)] = 1,898.4108 RPM.
Given the above, it the car could turn 6,500, then its top speed would be 60(6,500 / 1,898.4108) = 205.43498804
Top speed in 1st gear would be 205.43498804(2.3322 / 14.0946) = 33.99283975
Top speed in 2nd gear would be 205.43498804(2.3322 / 7.9092) = 60.57698365
Top speed in 3rd gear would be 205.43498804(2.3322 / 5.1376) = 93.25667220
Top speed in 4th gear would be 205.43498804(2.3322 / 3.8532) = 124.34222961
Then, the correct calculated values would be:
(3,000 / 6,500)[205.43498804(2.3322 / 14.0946)] = about 15.69 (rather than not rounding about 15.83)
(3,000 / 6,500)[205.43498804(2.3322 / 7.9092]) = about 27.96 (rather than not rounding about 28.20)
(3,000 / 6,500)[205.43498804(2.3322 / 5.1376)] = about 43.04 (rather than not rounding about 43.41)
(3,000 / 6,500)[205.43498804(2.3322 / 3.8532)] = about 57.39 (rather than not rounding about 57.89)
Thus, with stock wheels/tires, the starting shift points would be the same as the revised-for no-rounding values for my setup calculated below subsequently:
(5,346 / 6,500(33.99283975) = 27.96
(6,158 / 6,500)60.57698365) = 57.39
The atrocious ones I calculated earlier for my setup, but now without rounding, are:
(5,346 / 6,500(34.28769707) = 28.20
(6,158 / 6,500)61.10243456 = 57.89
Thus, my conlusions about starting shift points are independent of the wheel tire setup. Perhaps I should have seen this independence because of proportionality before calculating, but I did not.
#37
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
Just thought of another possible problem in trying to determine at what rpm a shift starts.The analog tachometer is dampened so there is a lag time in engine rpm's vs tachometer reading.As you are accelerating the engine rpm's at a given instant are higher than the tach reading.
[/quote]
Hi Znod
I could not wait until tomorrow.I made 3 runs today I am am satisfied that my performance is not compromised.I do have to explain my numbers though.
I had uncontolled wheelspin on all 3 runs.Tach went to 6500 rpm"s while spinning the tires and shifted to M2.My speed at the shift point was less than 20 mph.The tach was below 2000 rpm at the start of M2.The goodyear tires are atrocious when cold(40 degrees).The car bogged tremendously at the shift to M2.Now for the times.
speed run 1 run 2 run3 ave previous ave Diff
0-10 .42 .38 .40 .40 .34 -.06
0-20 1.30 1.20 1.23 1.24 1.03 -.21
0-30 2.22 2.13 2.12 2.16 1.78 -.38
0-40 3.20 3.10 3.13 3.14 2.84 -.30
0-50 4.22 4.12 4.18 4.17 3.89 -.28
0-60 5.50 5.43 5.48 5.48 5.13 -.34
Terrible 0-60 times due to faulty start.Notice that after 30 mph I am no longer losing time to previous average. Even with the shift to M2 at less than 2000rpm's the times were not drastically affected.
The 3 horsepower readings were 336,330,and 330 repectively.I am using 4000# for weight,if I use 4100# they would be higher.
In summary I believe these results show no loss of performance in my engine.I will have to wait for warmer weather to positively prove it.No matter what starting method I tried the tires went up in smoke even if I was already moving in M1 when I stepped on the gas I got instant smoke.
#38
Originally Posted by grogan545' post='235302' date='Feb 5 2006, 05:27 PM
Hi Znod
![Barf](https://5series.net/forums/images/smilies/imported/barf.gif)
#39
Hi Znod
[/quote]
This is not all bad news for you Znod.It means there is not something inherently wrong with 20.01.You are left with several possibilities.
1-There is something besides 20.01 that is causing your problem.Not likely since you noticed it as soon after you updated to 20.01
2-The software that your dealer is using has a flaw in it.
3-The download of the software was faulty.
I would either try a different dealer who could download 20.01 or have your dealer redo yours
I did notice when I was driving home from the dealer after my update that the first time I attempted a start I almost had no wheelspin and I went to full throttle immediatly,but the next start and every start since I get uncontrollable wheelspin.It seems the learning curve was very fast on mine.
I also did more checking in the hidden menu's.My tachometer & the readings in the hidden menu are very close.I could not see a difference.The speedometer however was off by approx 2 mph from the menu.Speedometer reading of 60 mph(cruise control on)indicates 94kph(58.28 mph) in the menu,speedometer reading of 40 mph indicates 61 kph(37.82 mph)in the menu.
Let me know how you make out with your problem.I will run more tests as soon as we get warmer weather.
#40
I'll keep you posted--one way or another. Thanks.
