Increased Emissions Warning Light?
Old Oct 5, 2014 | 11:44 AM
BRKracing's Avatar
My Ride: e60 530i
Default Increased Emissions Warning Light?
Hey guys the increased emissions light came on my 04 530i I took it to two dealers one being my local mini dealer (because they took all the BMW techs from the local dealer) and the second dealer being BMW itself. Mini had diagnosed the problem and told me it was my thermostat was bad. When I took it to BMW they said it was my DISA valve have any of you had this issue? Thanks
Old Oct 5, 2014 | 02:21 PM
BimmerFan52's Avatar
Thermostat can cause emissions light if it is stuck open (engine won't warm up fast enough) or if the heater coil is broken (ECU tests the heater coil circuit on start up). I had a heater coil fail, and you can measure the resistance of the heater coil to eliminate that as a possibility. Pull the connector off the thermostat and measure the resistance between the two contacts - normally measures around 16ohms, but if it measures 1 (open circuit) then it is gone. A broken wire in the harness leading to the thermostat will also cause the same fault but it is rare.
Old Oct 6, 2014 | 09:45 PM
Gangplank's Avatar
My Ride: '04 545i
Did you get a print out of the fault codes or read them w/ the BMWhat or Torque app?
Old Oct 7, 2014 | 06:27 AM
BRKracing's Avatar
My Ride: e60 530i
hmm Ill check that thanks man! I pulled out my disa valve and the valve was just destroyed. so that will be getting replaced this week
Old Oct 7, 2014 | 06:29 AM
BRKracing's Avatar
My Ride: e60 530i
No I didn't I blanked on getting them Ill ask the dealer and get a print out today
Old Oct 18, 2014 | 09:09 PM
lazye60's Avatar
My Ride: E60 530i 6 speed stock. AFE cold air intake
Is your E60 6 speed manual? If it is, you might want to check your clutch. I had the same problem with my E60. I kept driving it and my gears wouldn't catch up to its speed like it normally would. But I changed the clutch and the Increased Emissions warning light is gone and my E60 is good as new.
-Josh
Old Oct 19, 2014 | 08:37 AM
vkhong's Avatar
Model Year: 2010
Inspect your fuel filler cap as well. Clean the cap thread and seal, especially if it is dirty. You could use a little amount of fuel on a clean rag to wipe.
Katitu
May 23, 2015 01:46 PM
2004_545i
Apr 8, 2015 04:01 AM
E60Nut
Apr 16, 2004 03:33 PM
JR
Jan 22, 2004 07:26 AM
dv8ed
Dec 24, 2003 07:41 PM
