Increased battery discharge when stationary solved & question
Old Apr 16, 2015 | 12:52 AM
BMW5E60's Avatar
My Ride: 520d E60
Default Increased battery discharge when stationary solved & question
I observed that the reason for the error message was caused by short-circuit in a wire between the F25 fuse and the DSC unit.
When investicating more, also observed an abrasion in the wire near by DSC unit, which finally stripped insulation off from the wire causing the short-circuit.
Now the question is: How could it be possible that insulation layer was stripped off or What could cause the abrasion ? Maybe the car has been run-in by the original owner ?
Awest91
Sep 17, 2022 11:05 PM
DavaiLave
Aug 2, 2022 02:16 AM
windnsea
May 25, 2015 09:49 PM
brian1225
Apr 16, 2004 05:59 AM
