Ihka not work
Old Aug 2, 2022 | 05:44 AM
AriseE60's Avatar
My Ride: E60 530d 170kw
Default Ihka not work
H​I can someone hellp me please?
I have problem with ihka
When I finished replacing the heating regulator, ihka it stopped working, it doesn't light up, it doesn't respond.
All fuses its Ok, when I use new ihka its the same. I don't see any damaged cable. When I check on the first connector from the left on ihka it has 0 volts
Old Aug 2, 2022 | 06:25 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Did you unplug the battery before doing the work?
Old Aug 2, 2022 | 10:07 PM
AriseE60's Avatar
Unfortunately, no 😅
Old Aug 3, 2022 | 03:58 AM
Do you notice anything else not working in the car. That's a big job to keep the battery plugged up so you may have damaged something else.
Have you looked for codes? Have you unplugged the battery for 15 mins? How far have you traced your work to ensure you didn't miss anything while putting it back together?
Old Aug 3, 2022 | 04:42 AM
AriseE60's Avatar
Everything else works, I assembled everything correctly and connected it
now I waiting for inpa dignostics on suturday
Speedlimit?
Jul 31, 2018 05:54 AM
S.mcc
Jan 30, 2018 12:15 PM
SECC
Jun 29, 2017 10:14 PM
milkox
May 2, 2016 12:07 PM
AchtungE60
May 11, 2013 10:06 AM
