iDrive Brake Pad light reset
Old 05-15-2012, 04:54 PM
AchtungE60's Avatar
My Ride: E60 530i
if you try to reset when your sensor is bad you'll probably get an error. If you still have error, make sure your sensor is seated correctly and'/or plugged in.
you wont have to remove pads to put sensors on from what I remember. just some long needle nose pliers or a long screwdriver to unseat the old one. Just put pads and rotors on my rear. I used my old sensor because I was able to...rotors were bad but pads had some life. But when replacing rotors i would always suggest pads too.
Old 05-18-2012, 02:32 AM
thomas finlass's Avatar
My Ride: 2006 525i M Sport Carbon Black Cream Leather Interior
I've had this pop up on my car before, the iDrive told me I needed to replace the rear pads, which I did, but it wouldn't let me reset the service indicator......took the pads back off, replaced the sensor and guess what...reset perfectly. Sometimes you can get away without having to replace the sensor..if you replace the pads BEFORE they have worn down to the metal on the sensor you won't need a new sensor..if not....order a sensor when ordering the pads.....a sensor here in Ireland only cost me 12euro.
Old 05-19-2012, 04:02 PM
Rgortex99's Avatar
My Ride: 2008 528xi
Originally Posted by ponnu
Did you replace the sensor?
Now I did but Im getting a sensor error with yellow brake light
Old 10-05-2012, 07:17 AM
Bedford530i's Avatar
My Ride: 2004 530i 6-speed Titanium Silver/Black Interior Premium Package Sport Package Aux input 30 GB video iPod Cold Weather Package Xenon Red rear reflectors Tint Clear Bra
Default Worked!
I recently had to get my brake pads changed and had it done at Munro. Had all break pads changed and ended up getting my rear rotors changed as well (car would shake a little when braking) - car no longer shakes when braking!
However, the brake pad light remained on even after following the Youtube video - -15000 was displayed and it would not reset. I had to visit Munro again and have them make sure that the sensor was installed properly -- did the reset maneuver again and this time was successful.
Thanks!
BMW565
11-06-2017 06:03 PM
TexaZ3
05-06-2015 09:54 AM
Sakru
03-26-2015 09:26 AM
jhalsey
01-25-2004 04:34 PM
08-12-2003 11:41 AM
Quick Reply: iDrive Brake Pad light reset
