Idrive, Bluetooth firmware/ Software version
I am sure this has been discussed in other forums but I tried to follow the instruction to check Idrive firmware/ software version but I can?t get to that option. I remembered once while back I get in to the Idrive options and it was in German or something like that but for sake of it I can?t get back to that option.
Basically, I followed hold down Idrive for 8 second, turn right 3 times?. (While key is in the ignitioan, while car is on, from main menu, etc.) But I am no longer able getting to the Idrive hidden menu.
I have a 2008 528I and I need to check what Idrive software version I have and also I need to know what the current Idrive software version for my car is?
Currently, everything seems like working fine with my car but BMW wanted to charge high price for update but I wanted to know if they are not going to just re-load the same firmware/software?
Any help to identify my current car firmware/ software version and current available firmware version
I have a 2008 535i and looking for the same thing. I was informed that I should make sure the software is up to date before I look at doing the CIC retrofit.
I called two BMW close to my place and this is what I got from these lazy people,. It will cost about $200-$250 (Which I don?t mind). What got me they can?t tell me what version I have and what is the latest available version? They said I have to bring the car and they will hook it up to the machine and it will tell them if needed upgrade or not. What is wrong with BMW? I have done all my services prior becomes out of warranty, it got to be a way to look at work history, what version came with car and what is the available version and during these few years if they perform any update on the car.
This is a very basic information that can be obtain easily from their system.
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
If you get a whole bunch of German programs/versions, but not the overall version, then you're semi-recent, but there is no way to tell just what integration level you're at.For example, my 2008 550i came with the "updated" software (so I couldn't check the level in iDrive), but has needed several updates since to deal with different issues (ie. transmission hesitation, rough idle on cold start, 6FL iPod functionality, etc.)
I too am trying to find the software version of my iDrive.
On reading peoples comments on this site and others, it looks like there isn't actually a software version displayed within this menu anymore if your running the software from late 2006 onwards.
Would anyone know any different to this?
If I scroll to "Versionskontrolle" then scroll right to the bottom I get: "09-2006_I-510_20060426_0932"
(See picture)
Any help would be appreciated.
(See picture)
The way to look it up in iDrive was removed with a major update in April '07 (if I recall correctly). By all means, try the iDrive steps -- if it works, then you DEFINITELY need an update
