I GIVE-UP!
what everyone else said and i just had my pads and rotors done as well, i went with the akebono euro pads though, the braking has a bit less bite then oem bmw but theres barely any dust and ive only heard a very faint squeel couple times but it was barely noticeable.
Any knowledgeable mechanic (PepBoys, Midas etc.) can lube your brakes (it's simply a matter of applying the lube on the back of the pads and on the notches where the pads slide in the caliper), you'll just pay for the labor.
X2 Love them a little less bite but no dust and no noise.
check your anti rattle clips and add a little anti seize on the tips of those and that will help, the pads slide on the carrier and that will need some antiseize, and some lube on the sliding pins. Most squeeling is from metal to metal contact not always pad to rotor contact. For a test take some brake cleaner and spray down your rotors and calipers than do some braking again
My Ride: 2004 545i TITANIUM GREY II on Black Dakota Lthr, Comfort Seats, Sports PKG, Premium PKG, Active/Dynamic Drive, NAV, Winter Package.
Thanks guys for all the inputs. I will start tomorrow with the cleaner as it is the easiest thing to do and see if that would make a difference. It's just weird that it happens with three different sets of pads!
My Ride: 07 E61 530d M-Sport.
