I dropped a screw into my intake pipe? Any ideas on how to get it out?
Hey guys,
Today the past 36 hours were all-time for my E61:
- changed the power steering fluid
- replenished the tailgate hydraulic fluid
- replaced wiper blades
- changed cabin air filters
- installed AR downpipes
- flushed the transmission fluid x2 and changed the pan/filter
- installed an ER charge pipe with a Tial
While installing the ER CP my BMS cone intakes were removed and while I was lowering the CP into the engine bay I noticed that the screw/grommet that was just placed into the mounting flange -was no longer there. I didn't hear it fall but it wasn't on the workbench I was just at nor was it on the garage floor (just installed the grommet/screw to the CP and walked 10ft to the car). I searched all over and couldn't find it.
Anyway I am fairly certain it fell into the intake tube that runs to the front turbo. I went for a short test drive and noticed an whistling noise while under throttle (in addition to the turbos), I quickly turned around and went home. Under closer inspection with the hood open and filter removed I could hear a faint *ting*ting*ting noise much like a penny in a sink disposal and I am almost certain it is the screw/grommet bouncing around on the turbine.
Any ideas on resolving such a predicament? Where the intake pipes meets the turbo housing is in tight quarters and I am not sure how much work it would take to separate the two.
Would it be possible to run a shop-vac or air compressor and blow it out? I could separate the cat-back from the turbo and get in that way. Would this harm the turbo?
Anyone ever encountered such a problem?
Thanks,
Evan
Thanks,
Evan
Ouch! I dropped a metal speed clip in my old 280z when I was installing the weber throttle bodies. I couldn't get it out. Had get head removed! Have you tried a magnet of some kind? What about one of those soft rubber tube things they use to clean out the lint in the house drier, perhaps you could tape up something like this to your vacuum and snake the tube down to the turbine. I can't envision the length or maneuvering you would need to do. I'm sure it would be a bad situation if you left it in there though.
My Ride: 535i M Sport
Model Year: 2010
If it did fall in there and make its way to the turbo, the turbo is toast. But I have a feeling it didn't drop in there and is actually resting on the bottom pan.
Thanks for the responses so far,
Evan
Here is a video of the sound:
BigxPx
04-23-2015 10:11 AM
thesalboy
04-08-2015 09:13 AM
md750i
04-08-2015 06:08 AM
