I drive errors
Old Dec 14, 2009 | 04:27 AM
jimyboyle's Avatar
I have a December 2004 530D, only had it a few months. About 4 times in the past few weeks, when starting from cold in the morning the i drive has come up with - drive control system error, and the ABS and puncture warning failure messages. Later in the day it starts and the errors have gone.
Once it also said to check the battery connections, they were fine. This morning it did the same, but when restarting later the yellow battery warning light came on. Then on a further restart the battery error message cleared.
Went into a local garage, they checked the battery, which they said had good voltage but the Bosch checking machine said it was only accepting a 60% charge.
With the engine running the voltage at the battery showed 14.75 volts so seems the alternator is working.
I have realised it is when the outside temperature is quite low that this error comes up.
Does a failing battery cause these errors to be displayed because of the demands when trying to start a cold engine?
Jim
Old Dec 14, 2009 | 04:40 AM
Krozi's Avatar
As far as I know, cold weather decreases battery life/performance. It could be that your battery is nearing it's end and the cold weather is not helping.... I'd switch out the battery
Old Dec 14, 2009 | 05:46 AM
jimyboyle's Avatar
OK I went along and got a new battery, probably was the original so 5 years old. Can someone tell me how to reset the i drive?
thanks
Jim
Old Dec 14, 2009 | 05:51 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
thanks
Jim
Some more info please. What do you want to reset in idrive?
Old Dec 14, 2009 | 06:02 AM
Howitzer's Avatar
He probably has to go to the stealership.
Old Dec 14, 2009 | 06:08 AM
Anzafin's Avatar
Yes.
jimyboyle:
- If you want to clear all the errors, you have to go to a dealer or some independent garage to clear them. I'd prefer an independent as it should not be so expensive.
- If you want to get the battery "registered" for your car (if it's not done already), then the same as above.
- Antti -
Old Dec 14, 2009 | 06:31 AM
jimyboyle's Avatar
Went to car to set the time and date, done it, and all the other settings seem to have returned to normal.
jim
Old Dec 14, 2009 | 06:40 AM
Anzafin's Avatar
jim
Good to hear.
Some errors may stay in memory but you don't have to worry about them. They will be cleared next time when you visit the dealer.
DavaiLave
Aug 2, 2022 02:16 AM
Stranger12
Jan 21, 2021 06:19 AM
Randmaster
Apr 2, 2019 07:58 AM
nathanhun
May 8, 2015 04:04 AM
Don dario
Apr 30, 2015 10:59 PM
