I drive
Is there a way for the I drive to go straight to a particular function after I hit the accept button? I like the map and the current position on the side, but either I have to say map direction of travel or right on the I drive down three times and then click down. In my range rover it goes straight to the map after hitting accept.
If there is a post allready discussing this could id be glad to follow the link.
If the map is the last screen you looked at under the NAV category, then next time you boot up iDrive you can bring up the map (or whatever screen you last viewed) directly by holding down the controller in the right direction for 3 seconds.
Works for all 4 directions/categories.
Awest91
09-17-2022 11:05 PM
pigment
09-15-2019 11:34 AM
