Hud
Old Feb 26, 2018 | 06:22 PM
spazzz's Avatar
My Ride: 2008 535xi
Model Year: XHP&MHD
I just adjusted mine yesterday.
Try raising the image by adjusting it. There is 2 T10 torx screws holding the Idrive in. It will tip down and out.
Let it dangle and grab about 18 inches of extensions for a 13mm socket and wrench. Loosen it little over 180 degrees then use a 6mm for the tip of the threaded shaft.
About 90 degrees loosen (lefty loosey) should put it in the sweet spot. Loosen it more if it doesn't.
If I would have known the 6mm would get stuck on the shaft I would have used some silicone paste in the socket. I got it out with a long needle nose and some wiggling.
Old Feb 26, 2018 | 06:30 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
https://en.wikipedia.org/wiki/Brewster%27s_angle
Old Mar 3, 2018 | 08:33 AM
NoQuarter's Avatar
Engine: N54
you are certainly correct but it seemed you implied that because of this specific angle they needed to polarize it and with a different angle they would not.
The thickness of the glass would give a double image in nearly any scenario I think.
Neat wiki article.
ACEE
Apr 17, 2006 04:38 AM
555
Feb 5, 2004 09:38 PM
555
Jan 11, 2004 01:51 PM
Guest_Aaron
Sep 17, 2003 05:52 AM
Beemer
Jul 7, 2003 12:01 AM
