Hub assembly replacement, need DIY help
My Ride: 2006 530i
Hello, I own an '06 530i. My driver side front wheel has developed and annoying wobble/viberation around the 70mph+ range. I recently did a front brake job on the car and when I spun the wheel I noticed a wave motion in the rotation. The passenger side spun on a straight line. Initially I thought I bought a bum rotor, so I exchanged it and the 2nd one did the same thing as the 1st one. I believe the wheel bearing/hub assembly is at fault.
I've done this job on my 99' E46 328i and it was a piece of cake. I'm wondering if the 530i is as easy. Has anyone out there performed this job?
My Ride: 2010 550i M Sport
the easy way is to remove entire front axle, to do it on a car is a PITA
done it on E39 should be the same for E60
posts #93-109
http://forums.bimmerforums.com/forum...8#post23701588
posts #93-109
My Ride: 2006 530i
Front axle? This is a rear wheel drive car, don't recall seeking axles up front. I need to take a closer look. Can't recall if I saw an axle nut up front. Really wasn't paying close attention. I guess if there's front axles it would be apart of some traction control set-up.
My Ride: 2006 530i
check real OEM
RealOEM.com * Diagram Selection
My Ride: 2006 530i
Mihainede85
03-11-2015 09:45 PM
mikekilpatrick
03-06-2015 05:40 AM
