How to show fuel usage on instrument cluster...
Old Oct 19, 2009 | 03:36 AM
Mr.Bavarian's Avatar
I have no idea how to do this, but when I first bought my car, there was a little reading on the cluster which showed average fuel usage in the form of, ie: 12.4 L/100km
Now I've noticed this has somehow disappeared recently and replaced with a temperature reading. Anyone know how to get my fuel usage reading back? I've literally
pressed every button inside the car in every sequence imaginable - but no go. Anyone know whats going on?
Old Oct 19, 2009 | 03:42 AM
MariusRix's Avatar
Hi, Yezero! On the indicator stalk are two buttons, one says check and other - I think! - is B/C. Press this button in continuously and it should give you distance remaining on fuel left in the tank, average speed and fuel consumption. By keeping this button in for a few seconds in any of above readouts, you can cancel the particular reading and start afresh. Hope it solves you problem!
Marius
Old Oct 19, 2009 | 04:24 AM
sixcard's Avatar
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
Hello Zero ... which is how much we (at least I) know about what you drive.
Tell us about your car. Model year in particular.
Also, once you find how to view it on board, it is best to compare it with actual pump usage over an extended period. Mine is consistently over stated by at least 1/2 GPM.
GL
sixcard
Old Oct 19, 2009 | 06:41 AM
gerrypd's Avatar
it's the lower button on the indicator stalk. Just toggle it until you see the MPG indicator.
Old Oct 19, 2009 | 07:14 AM
luigi524td's Avatar
Thumbs down
And you can actually customize the readout and display the same info on iDrive (Onboard Info) ... it's all in the manual!
Old Oct 19, 2009 | 01:30 PM
tooltec's Avatar
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
I guess you want MPG rather than L/100km anyway.You need to go into iDrive settings to select .Also,ensure that under "units" that you select US mpg,not UK mpg.When you toggle the lower button on the indicator stalk it shows average speed,or average mpg,or miles to fill the tank,or blank.As stated already,it's all in the handbook.
Old Oct 19, 2009 | 01:32 PM
CWS530's Avatar
Originally Posted by sixcard' post='1035587' date='Oct 19 2009, 07:24 AM
Hello Zero ... which is how much we (at least I) know about what you drive.GL
sixcard
Old Oct 19, 2009 | 01:34 PM
tooltec's Avatar
GL
sixcard
My average mpg was out because the wrong units were selected in iDrive.You have the choice of UK mpg or US mpg.Have you checked in iDrive?
Old Oct 19, 2009 | 01:36 PM
tooltec's Avatar
GL
sixcard
Double post in error!
akaveli3
Jan 12, 2021 08:46 AM
Bounce
May 4, 2019 01:32 AM
tpaulus
Aug 16, 2015 03:24 PM
rkilpa
Aug 4, 2015 06:14 PM
ali-d1936
Jul 26, 2015 05:32 AM
